I have the new Z10 Pro Max, use MYTVO2 with a provider XC login Portal.
Everything has been working great, then all of a sudden I get the message (An error occured:UnrecognizedInputFormatException). I Googled it and all I see are posts about Tivimate.
I figured it had something to do with the stream being ts or hls. I don't know that much about it. I've tried setting up a m3u playlist using hls and ts output, per the provider suggestion but, that doesn't work either . Somewhere here I saw that the HLS Fast start setting is no more and is built in to MYTVO2 now on the Z10 Pro Max, so that should make setting up a m3u playlist unnecessary IMO.
I believe this to be a provider problem but, naturally, they won't admit to anything. I know they have been having problems since they switched over to a new panel for 2-3 months now. Things seem to hit and miss with different channels. They said the panel automatically creates various formats based on the user...???
What I can say is that the few channels I get this error on are specific to a few US channels. It is not random channels.
Any ideas or thoughts would be appreciated.
