Since switching from the Z Alpha to Z10 Max, noticed a lot of files in the VOD section with audio sync issues.
If I pause or rewind content briefly & unpause/play, then it seems back in sync for a few seconds, then you see a frame skip, then back out of sync again.
This seems to. be affecting a lot of files and did not have the same issue with Alpha with the same service?
