I have the following problem with hiding groups from live tv. Previously it worked fine, so I think it's a firmware problem.
I use the adjust option inside the connections menu option.
Hiding groups in vod/series is not a problem. But hiding groups from live tv, results (after some loading time) in an 'empty group' notification popup. After returning to live tv, live tv is empty en gives a black screen. Only a reconnect helps bringing the channels from live tv back.
But still I cant edit the live tv group. Ive done a complete factory reset, but the problem remains..
Anyone has a solution? I use a z8.
