When using IPTV Smarters app all radio channels work perfectly.
Please check PM
Please check PM
in the channel list why is there not an ALL CHANNELS like there is uk entertainment etc.
there is no all in tv series or vods so when you want to search you only search in catagory your in.
no radio channels come up.
Please read this thread -> Mytvonline3 - What’s New?
No4.
Hi sam please lets us know if there is an issue with HDR10+ on the z11 pro max ?
Like 175n wrote, all fine with HDR10+. Please check my test and video file.
hello, has anyone solved the problem or that and normal I don't find its aesthetic and on mto there is all the complete info here on mto 3 the first page it's complete May from the second page the 1st channel from above and cut and the last too.
I have just checked mine and I too get that issue. It seems a scaling issue that only the devs can resolve.
If you change Channel List Style to “Normal” mode, the issue will not appear, however it will change the screen layout slightly.
On any channel > Menu > Settings > Channel List Style
I prefer normal mode personally.
Je viens de vérifier le mien et j'ai moi aussi ce problème. Cela semble être un problème de mise à l'échelle que seuls les développeurs peuvent résoudre.
Si vous modifiez le style de la liste des chaînes en mode "Normal", le problème n'apparaîtra pas, mais il modifiera légèrement la disposition de l'écran.
Sur n'importe quelle chaîne > Menu > Paramètres > Style de la liste des chaînes
Personnellement, je préfère le mode normal.
thank you for your answer I saw that nobody had to speak about this concern so I went up the info I prefer this menu because there is all the information on the screen and I find the logos of the chains asser large.
I would think many would also agree with your preference for the channel list style.
I’m sure the devs will see this as a scaling issue and resolve in due course
Je pense que beaucoup seraient également d'accord avec votre préférence pour le style de liste de chaînes.
Je suis sûr que les développeurs verront cela comme un problème de mise à l'échelle et le résoudront en temps voulu
thank you for your answer and yes I hope that will solve it in the next update.
Notifications within MTOL3
Notifications in the “All” tab cannot be deleted.
Many may not consider this an issue but for the people who don’t like clutter, it would be nice to have the option of clearing notifications
Beta uupdate solved issues with limited channels on Adult (xxx) now I can see all channels instead 14 only
Yes, confirmed and forwarded now.
Was already requested and forwarded. See also this thread -> Notifications
Thx. for the feedback. Have a nice time ![]()
After update lot of clitsches on the tv channels... Not smooth looking... Maybe it's a moment... But is was on all of the channels... Tomorrow I test again 😄
Hello, in the Formular settings, in display mode it is better to put in auto, 4K DCI 60 Hz, 50Hz, 4K 60Hz or 50 Hz. Thanks. I have a Samsung qled tv.
4K 50Hz for Europe and 60 Hz for America, depends from where you are.
You can chose what you like and feel it is good for you. 98% of iptv content are sd, hd or fhd.
Something about this thematic for better understanding:
We have written an article explaining to you what Refresh Rate/Frequency is (sweep frequency) of a TV. Check out this link to access it: What is TV refresh rate 50Hz, 60Hz, 100Hz?
To summarize what the refresh rate is, which can also be called melt index. It can be compared to the frame rate per second that tv is capable ofdisplay. 50Hz equal 50 frames per second, 60Hz equal 60 frames per second. This has an influence on the sharpness and fluidity images. You will notice this if you watch a program with “fast” images. For example, if you are viewing a action movie with lots of car stunts or if you are playing a video game. However, it is quite difficult to tell the difference between a 50Hz and 60Hz TV, because the refresh rates are very close.
The difference between a 50Hz and 60Hz TV simply comes from different broadcast standards worldwide. Indeed, in France the standard frame rate for TV broadcasting is 25 frames per second (PAL). However, in the United States (USA) for example, the display frequency is 30 frames per second (NTSC). It is for this reason that there is a difference between 50Hz and 60Hz TVs. The 50 Hertz TV will operate at 50 frames per second (European standard). And the 60 Hertz tv will be at 60 frames per second (american standard).
But now, most of the time, you will see displayed in the user guide of your tv the refresh rate like this: TV 50Hz (60Hz). It simply means that your TV is able to tell the difference between the frequency 50Hz and 60Hz. That is to say, if the source (tv decoder, Blue Ray DVD player) sends a video signal at 25 frames / second (European standard). Then your television screen will broadcast the images at 50 Hertz (50 fps). But if the signal source is 30 frames per second, your TV will broadcast your Programs at 60 Hertz (60 fps). The No worry de image processing embedded in the 50Hz (60Hz) TVs this will take care of doubling the refresh rate so that your viewing experience be more fluid.
Source: mytv-solution.com
I have an EPG Issue running my Z11 pro max. EPG only shows 2-3 hours in advance. Known bug or is there already a solution?
(EPG still updates and information is filled during the day but still only shows as above)
I have similar problems.
Does automatic epg update work for you?
Are you on MAC ID?
Are you on MAC ID?
I tried a couple of different settings when it comes to automatic update. Didn’t change anything. Now I have it on 3 hours which I believe was the default sitting.
On MAC ID yes.
hello, i have two providers to record on the Z11 , both in xstreamcode. I created my bouquets by mixing the two servers. I changed the URL of one of the servers and after putting refresh, I lost all the chains of its servers. Is this normal and is there a trick to avoid it? When I go to portal will I lose everything again. Cordially
If you change the portal data in this case the url, update data (<- of course you change also your favorites and done changes with this portal). New url means new portal.
Thank you for answering. On the Z8 or Z10 pro max I often changed the URL and I always kept my bouquets weird
Please check PM
Hello. Could you please give the solution I have the same problem. thank you.
Same bug as others have mentioned
Radio channels not working on z11 pro max
Work fine in z10 pro max
Hi, a friends relative of mine as just purchased a z11 pro max and he’s saying he also as no radio channels. No uk radio channels showing at all and on the main menu radio tab it’s showing 21 channels with no audio at all. Not just a coincidence a issue with MOL3 I believe.
For my part, no problems with the radios on my 4 subscriptions with the Z11 Pro in Mac Address.
Please check PM
For me also everthing slow inregards to changing channels and also epg slow to form up.i m sure this will be corrected next update.mine is z11 pro
After updating to the beta,mytv app forced closed a few times in a row but seems to have settled down down,plz fix resolution and sound settings,if I change resolution from auto4k to 1080p and sound setting to raw it works as it should but when I reboot it goes bck to auto4k,my z10/z8 would keep the setting on reboot
I have an issue that the remote does not work after shutting down the box. Not able to turn back on. Also every time I remove it from the power and I can get it to work again it tells me it want to shut down. I have some seconds to cancel this
Hey!
Vod and TV series are gone and I have the new update.
what can I do? What i haven't done is reinstall MYTV can that help?
Did you set Power mode to Shut down?
How many hours after turning off the device did you turn it on?
Is CEC setting enabled?
Hey!
It is a known issue and the developers are working on a fix.
In the meantime you can go to
Menu > Content Manager > Content Sources > Press the reload button at the top of the screen
Thanks 175n!
That's what I've done for 2 days now but it doesn't help.
Looks like I'll have to wait for an update/fix
Thanks 175n!
Please try to delete the portal and re-add it to the content sources to see if it helps.
Write down all the important portal info before you delete it.
This issue should be addressed in the upcoming update.
I removed the portal and now I have Vod and tv series again.
Thanks 175n!
on gtv or z8 when the url is modified the list of favorites remains on the gtv and z8 but on the z11 the favorites are lost if the url is modified.
Same with my Z11.
Setting power-off to standby works fine.
However setting power-off to shutdown causes problems to turn back on the Z11 with the remote.
Immediately power-on after a power-off will succeed but power on after a couple of hours is not succesfull and you have to plug out/in the power cord to get the Z11 started and immediately cancel the suddenly appearing shutdown.
HDMI-CEC has been switched off on the Z11, but the power-on error still remains.
Hi how do i change to the second portal on z11 max on z 10 i just went to connections but tried every thing on z 11 max
any help, please
potash
Use standby instead of power off.
Is normal, the 10sec. counting begins when Box booted, press ok or cancle button once, this stops the countdown. It happens only if the box was powerless and want to go into last state.
By putting everything on standby, it still happens that you have to unplug the Z11 to be able to turn it on again. It's getting really painful Thank you for doing the necessary quickly for all its bugs
