Z11 Pro Max Help
  • Hi everyone, i am new here and to the formuler boxes, i did have a nvidia shield 1st gen
    I am due delivery today of my z11 pro max and would like your advice on best setup.
    Is it best to use mtv3 or tivimate?
    Is there any must have apps i need to install?
    can you install a personalised launcher?
    Any help would be appreciated
  • Focus on Z11 should be MOL3 , most reason for many user to buy this box. If user think its for him better to use some other iptv app then its his decision and that is ok, but please on Formuler forum should the focus stay on Formuler products. Thx for understanding.
    - Try first included Mol3 and decide later if you need Tivimate or not. On NS was normal to use such app, on z11 no need for such app.
    - Formuler remote app if not installed.
    - No other launcher, but learn first the box and see if its enough or not.
  • I would use mol 3, I tried tivimate too but that caused trouble with my box. Tivimate is a much better app with more options though.
    Tivimate has more stuff,i can give you that, but it's not better, actually it's worst. only thing tivimate has that i miss in MOL3 is the studio mode up to 4 channels at the same time (can be more - not sure) and the ability to use software decoders which gives a better sound in some cases. Other than that i prefer MOL3 interface any day of the week LOL And VOD on MOL3 is another level when compared with tivimate LOL You can say tivimate is a little tiny bit more stable than MOL3 in the present, but MOL3 will surpass it and we all know what tivimate new versions can bring LOL
