Hello staff,
I'm trying again because I don't understand and I'm a bit frustrated. I've tried loading my m3u file from "Add m3u playlist" in z11 with three different m3u files from three different providers, and none of them work. I've been told that the issue is with my m3u file.
(And all m3u files are from three different providers and they still don't work.)
So, my question is: there must be someone from the Formuler staff who knows how an m3u file should look for mytvonline3 to be able to differentiate between VOD and series.
Is there someone from Formuler staff who could kindly upload an m3u file or write here how it should look to work with your system?
And if it's not possible, then why can one even use the "Add m3u playlist" function? You might as well remove the function.
Furthermore, in my view, my problem is significant because I can't load my series into the series folder, and everything comes into the VOD folder, which is a crucial problem.
In my opinion, it's just a code problem. I code programs myself and know that it should be possible to differentiate between movies/VOD and series.
If only VOD Smart Grouping could be added to z11, it wouldn't matter whether movies and series were in the same VOD folder. But currently, without VOD Smart Grouping, it's very confusing.
I hope this can be resolved as I'm very happy with all the other Formuler boxes, and I've made boxes for 20 people. But if I can't upgrade to the new boxes in the future for myself or others, I'll have to look for another box. So, I really hope we can get this issue resolved.
Best regards,
Offenbach
