When NordVPN is enabled on both of my Z11 Pro Max devices(latest version), I do not see the VPN key on the top right of the TV screen, however when I enable TorGuard VPN I can see the VPN key, anyone any idea why the key is not visible when NordVPN is enabled?
VPN key is not shown when VPN is enabled
- Z11 Pro MAX
- Apps
fhuggie -
March 25, 2023 at 10:14 PM
if using the express vpn client on the box try updating to the latest version from the gplay store.
the formuler market one is outdated.
Yes you are right I have the same problem with Nordvpn on Z11 pro max I complained about this in an earlier post and couldn't get a fix. The strange the thing is that I have a Z8 and Z8 pro you see the key icon displayed when connected to nordvpn through a router or the nord app. I wish the developers would take a look at this and solve this problem.
if is the key icon
check in app notifications and allow all for the vpn client.
Where do I exactly find those setting?. If I go to Formuler>settings>Apps>NordVPN, I can see notifications are enabled.
Where do I find option ‘allow all for the vpn client.’?
Thank you for the clear steps, I now see the VPN key on TV scree when NordVPN is enabled👍
You`re welcome.
Display More
1. Download latest Android apk version from Nord VPN Homepage on your Z11 stick.
2. Connect with box and use TV file commander for install.
3. Through install process there will appear following message:
Press Ok.
The key will be shown when VPN active.
Hi Sam in my case my nord VPN is through my router that all devices connected are connected to nord VPN. I do not have to download the nord app from the market store. My problem is that my Z8 , Z8 pro and Z11 pro max are all connected to this same router while the Z8, Z8 pro show the key icon the Z11 pro max does not show the key icon. Sam what am I doing wrong? Please advice. I don't have to download the VPN app because nord VPN is active in the router
When the Router use VPN directly, there is no any need to show such key because all data packages from entire Inet. goes through VPN Server, it is always safe.
Why Z8 shows the key and Z11 not could be some code optimisation that is in Z8 firmware included and in Z11 firmware not.
