My wifi router broadcast wifi in 5G as well as new AX (6G), and note (AX (6G) is much faster than 5G.) however Z11 Pro Max only recognizes 5G as well as standard wifi, when searching for available wifi it does not show AX (6G) wifi, I have IPv6 Enable as well on Z11. note Z11 pro max advertises as compatible with latest AX (6G) my device is up to date with all the updates.
6G (6 generation) AX Wi-Fi
- Z11 Pro MAX
- MYTVOnline3
Mparto -
April 13, 2023 at 6:32 PM
wifi6 use the same 5ghz band only wifi6e using 6ghz band.
z11 is the 5ghz band(wifi6).
z11 uses AX. according to comcast and ATT AX is same as wifi 6e using 6 ghz band
the rtd1319c used on the z11 has wifi6 and not the wifi6e(which has the 6ghz band)
wifi6e is an extension of wifi6.
formuler staff/forum can better confirm.
Z11 series devices support AX wifi on 2.4G and 5G bands.
Wifi 6e (6GHz) is not supported.
thought so because the 1319c only support wifi6 and not 6e.
I have 1 formuler z11 pro, since I change hub with wifi6 mytv3 doesn't work.
Does the connection, load the channel but stays black screen, any ideas?
Please read post #5 in this thread.
Check if Youtube works
