Hi GTV Team,
In my Master Bedroom, the Connection to my TV (HDMI) is in my closet. There is a shelf in the closet with power and that is where my GTV is located etc.... The issue I am having almost daily, is the remote keeps dropping Bluetooth connection. I have to open the closet door and using IR go back into the GTV settings into remote and accessories and hold down the menu and okay buttons on the remote to repair it. The GTV and the BT remote are all up to date. I tried replacing the batteries thinking I solved the issue but each day the BT drops connection. Is this happening because the remote needs to be constantly communicating with the GTV and because it is in a closet, it is losing signal? I am at a loss........
