Im trying to get i to the root folder of my formuler z11 box. I want to copy over football that i have recorded, So i have my IP Address, but what else no i need at the end of the IP Address, Would it be 192.168.x.xx :8080...as not getting in using the 8080...Thanks
z11 root folder
- Z11 Pro MAX
- Hardware
wullboy -
May 13, 2023 at 9:06 AM
Z11 doesn't have a built-in file server.
Install "TV File Commander" from Play Store and use the "PC File Transfer" feature to move files to your device.
ok 175n thanks for this, so m8, where would the recording files be located in my external hard drive, as theres no way of seeing the pathway...thanks...
I have same issue here , i cant join pathway (\Android\data\tv.formuler.mol3.real\Recordings) on external hard drive or usb keys, with files explorer apps
I try with X-plore File Manager app and activate unhide hidden files settings, but still no access
The only way to join pathway is use SMB protocol over my NAS I can access to files via pathway
On Z11: Android -> data -> tv.formuler.mol3.real -> Recordings -> Recorded files in subfolders.
I tried “TV File Commander” (by mobisystems.com) which I installed from the Play Store.
I even upgraded to the “Premium Plus” edition (on a trial basis).
Still, I could not access the Z11 recordings in Android -> data -> tv.formuler.mol3.real -> Recordings.
What are your thoughts?
1. if using windows you can try:
[TOOL] Android File System (Network ADB Extension) for Windows Explorer from the xda forum
but it will only work with external usb storage in fat32 format.
2. You can also remove the storage from the formuler and connect to the computer.
