Maybe you should consider swiching to XC api connection,just to see there has nothing gone wrong with the spelling of m3u list?
MOL3 z11 pro max "m3u list" 0 channel found
- Z11 Pro MAX
- MYTVOnline3
henkie -
June 11, 2023 at 11:04 PM
my 2 provider m3u and xc api work, but my safety free local channel list in m3u work on mol2 but found 0 channel in mol3
prsonnal m3u list work on formuler z10pm but not work on z11pm
try to change the end m3u8 to ts and test again.
If the issue still exist later, please open ticket, give detailed explain of the issue and provide real url for dev. test. thx.
ok tank-you SAM .ts not work, how to open a ticket ?
T o create a ticket,click on formuler helpdesk on the top of Homepage,go to orange chatbox in the middle of the right hand page,and create your ticket via the chatbox
ok tank you
I can't find the way to show my favorites of series on the homescreen.
Thanks for your help
in the mean time:
1. try switching the part of the url to &output=ts or &output=ts&type=m3u
2. try using a hard copy m3u by downloading it and placing on a usb flash then loading it from mol3.
down arrow to the bottom of the home screen and check in
launcher settings>customize channels
then check all you require.
by the way your question is unrelated to the subject of this topic(m3u)
in the mean time:
thist list not have, this is not provider list, this is a private list starting by "#EXTM3U"
#EXTM3U
#EXTINF:-1 tvg-name="name"tvg-id="xxxx.ca
my idea is because category "ALL" as removed in MOL3 ?
I don't think so because channels with no group get sent to the "nogroup" category.
Try to rename your playlist.m3u8 to playlist.m3u to see if there is a difference.
my list have . m3u extension, this is end of the url link ending by .m3u8 list work on mol2 but not mol3 stranger
#EXTM3U
1. since it is a private list well try opening it in notepad++ for example and resaving it as .m3u
2. install another iptv client on the z11 and also try importing the list.
my list is already in .m3u , and already opened by notepad , y have perfect player on my z11 and list work with perfect player
and y have z10 pro max and work on z10
1. Did you check in software update and install the latest updates for the firmware and mol3?
2. try doing a refresh after the m3u file is imported.
hi the z11 mol is strict and picky(which has benefits in some cases) compared to the z10 with m3u.
The m3u is now working, I had to sanitize it.
Working means the channels is now detecting(26 found) using the z11.
before cleaning, channels =0.
screen shot download:
good, tank-you very much for your help
