How to remove a config file on Formuler Z11. I can't add a new portal, because my Z11 is block by my old provider.
Go to system information, then go to the last choice (without pressing ok)
And tap 10 times out of 0.
You can now RESET!
Yes but this option is not available with the last update. Do u have a solution ?
System info was moved to the Command Center.
At the home screen open the Command Center by navigating to the gear icon in the top right of the screen.
The System Info widget is located on the second page of the Command Center.
There is a big problemwith the new software for the Z11 max Pro
Loaded new software version :v11.3.3 and revision r0x74599645
When i switch off the box with the stb knop and one hour
later again the stb knop to go on,
THE SCREEN STAYS BLACK and no possibilty to get a screen.
I have to unpower the stb and restart the complete cyclus
and after clicking the mytv online3 then works well
HOW TO RESOLVE THIS PROBLEM
greeting
Display MoreThere is a big problemwith the new software for the Z11 max Pro
greeting
knop NL = button ENGLISH
You can now RESET!
Have you tried this by your own? It doesn't work.
I got no device block. So i wait for devs and admins or they now were it is located
Not working on the new command center
How can I remove config file
Go to home screen > Comand center > move to second page and you should see 'System info.'
Then, please follow the guide below mentioned by Aton.
You can now RESET!
What is meant with
“Tap 10 times out of 0”
When I press 10x the zero button when the cursor is positioned on the last item (Build Date) of the second window/page of the Command Center, nothing happens.
What is meant with
Do you have a provider block and you can not add new portal?
Something strange is going on,i am not able to go to the second page of the Command Center.
What am i doing wrong,(see also post#9)![]()
In Command Center move cursor to the Help Center (lower right) option, then move cursor to the right, that brings you to the second page. (network Storage / System info / Power mode / Power)
Do you always answer questions with another question? If you know the answer, or can explain in what situation (only) that option is available then please explain. That would be more helpful to me and any others that might run into this situation. Thank you.
In one of your posts i read that you have 5 Portals,if you think one of your providers is blocked to your device,you should first find out which of your subs. is being blocked.
I asked you the above questions,if you can not add a new Portal,your device is provider blocked,if not however the described way to do unblocking,will be useless.
Its up to you to find out if any of your subs. is provider blocked,and if so follow the guidelines by F-Peter and Aton to unblock.
Have a nice evening in finding it out.Thank you
Henkie, in your initial answer you could have sufficed by saying that this option is only available if a portal is locked. Furthermore, my question was what exactly was meant by “Tap 10 times out of 0” since that is not correct English.
I know exactly whether my portals are blocked or not, no need for me to find out. Apparently your need to feed your ego is so strong it withholds you from being truly helpful as you prove in your last sentence. Quite immature.
All the best.
All the best.
You must have delusions of grandeur,or simply just born arrogant![]()
What is meant with
Should mean: If users box is Provider blocked, tapping 10times zero, delete the molcfg file and settings from the box. The Box start with factory reset and the user can set all fresh again.
Thanks very much for the clear and concise answer, much appreciated! 👍
This forum is visited and supported by a diverse set of users from around the world. All users are volunteers and spend their own personal time to participate or help their peers.
The main language of the forums is English but that doesn't mean only native English speakers (writers) are allowed to participate.
Please be kind and understanding of each others' postings, even if it is not written in perfect English.
Xenophobia, Racism, Discrimination, and Bigotry will not be tolerated.
Thank you for your cooperation.
