Dear Formulers,
How can i save my wallpaper in internal storage of the box? For now i put it on a sd card, but i need the SD card back for other things. How to put in the Jpg file in the box, so it should be save there.
How to save wallpaper in internal storage
- Z11 Pro
- MYTVOnline3
Ferdinand -
August 27, 2023 at 12:18 PM
download the TV file commander from the market place, then your external sd card will be displayed along with the internal storage. Then just cut and paste your image to where you want to store it
Hi there,
You mean send files to tv? This won't work here ik keeps on searching to receive transfer? Do i something wrong? -
no it's called tv file commander, when you plug your sd card in to your box, open the "tv file commander" app and you have all internal folders displayed, there you'll see you sd card which you've inserted in to the box. Then your able to cut and paste to your chosen internal storage folder. Then unplug your sd card. And the file will then be stored on your box
Thank you for helping out, now it works with the wallpaper.
so where did you save the file on on your internal storage
Create a folder called "Wallpapers" and add your images there.
what format & is there a certain size it must not exceed m8
Folder is no problem, you can put the Jpg for example in the pictures map. Using a JPG same like a computer wallpaper should be good enough.
