Since a week i changed from provider, also changed from Xcapi to stalker connection. But is it possible that the provider can put new movies and series in there without doing a manual refresh? Because for 2 days i notice now there are new movies and series added, without doing a refresh manual or automatic. Before with the old provider in Xcapi always needed to refresh by myself.
Does a stalker portal refresh automatic
- Z11 Pro
- MYTVOnline3
Ferdinand -
September 8, 2023 at 10:41 AM
Everytime you start mytvonline it updates.
so is it with mytvonline and mytvonline2.
The box is always in standby modus, no restart.
Then refresh.
I do always full shutdown.
The 25 seconds is ok for me to wait.
Everything is new and fresh start and containing all new channels and movies
Every time mytvonline3 starts it doesn't refresh, it updates EPG, refresh happens only if you set a daily time and/or do it manually, at least for me...
Yes, stalker should refresh automatically.
Never noticed that before, thats always easy so the provider can put movies/series in the background.
