BETA FW 10.10.48 and MOL2 10.10.50 Update released
  • BETA Software Update for Formuler Z10 Series devices.
    Firmware: 10.10.48 BETA
    MYTVOnline 2 : 10.10.50 BETA
    WARNING:
    HowTo Install:
    BETA FW 10.10.48 + MOL2. 10.10.50 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
    Change Log
    Firmware Version : 10.10.48
    • NEW: Update to Android security patch level February 2023
    • NEW: Formuler Help Center app. Watch tutorial videos and read support articles about your Formuler device.
    • NEW: Added Surround Sound widget on launcher. Easily check and change the system Surround Sound settings.
    • IMP: Added private DNS to the configuration template
    • IMP: HDMI output stability
    • FIX: Device turns on by itself sometimes
    MYTVOnline 2 Version : 10.10.50
    • FIX: "Failed to load VOD" error
    • FIX: Cannot play catchup on some portals
    • FIX: Delay in playing catchup on some portals
    • FIX: Crash during refresh
    • FIX: Watch history disappears
    • FIX: Crash when changing to a channel with "%" in the channel name
    • FIX: Some picons not loading
    • IMP: Improved support for VOB subtitles
    Please if you have some Bug to report, post cumulated only in this thread after many tests and not if this happen only once. Thank you.
  • Thx,for the update,as i have none of the problems described in the changelog,i will wait for the official update.
  • After some consideration i updated afterall,first thing that seems to be improved is VOd loading,will test further improvements over the coming week.
    Where can i find the Formuler Help Center app?
    Sorry,already found the app,its on Homepage!
    Edited once, last by henkie (October 13, 2023 at 7:27 PM).
  • it says firmware 10.10.48, not 47.
    Yes, fw version changed in last sec. Edited now.
  • Hi!
    After installed the new fw, i noticed that the help icon when selected it turns off imediatly.
    Is it only me?
    Best regards.
    No problem here,when selected Helpcenter it goes into menu,and after closing its still there.
  • for when the normal update is expected?
    Depends on reports that come in from beta update,if no serious issues arise beta automatically becomes final update,usually this is a matter of weeks.
    No one can give you exact date,SAM will announce the date of final update when the time comes.
  • Great improvement with my providder. The catch up are now playing. :folded_hands: The only issue I have is when I leave the catch up to go back to live TV, there is sometimes a big delay before I can see live TV. I have to change channel back and forth before it starts playing live TV again.
    Edited once, last by passingby: Spelling mistakes. (October 27, 2023 at 6:14 PM).
