The Z10 pro max is pretty stable is their any benefits to upgrade to the Z11 pro max?
Z10 Pro Max is it worth upgrading to the Z11 Pro Max?
- Z11 Pro MAX
- MYTVOnline3
Formuler All -
November 27, 2023 at 3:20 AM
Mytvonline 2 is much better then MyTvOnline3.
That is my opinion! I have 4 gtv's in house, and one Z7 and Z8.
But z7 and z8 i dont use anymore almost.
No! 10 pro max is more stable! Or tv online 2 is better than 3
Short answer, no.
For the moment no,but for the near future YES!
Clearly not ! I regret the Z10 and MTO 2
I really like Mol3 ! Ease of use, itv provider installation setup was seamless.
Can someone explain why tv online 2 is better than 3. I have need for another forumuler box and will get the z10 if the tv online 2 is better.
There are different subjective opinions about mol2 vs mol3.
I personally like both,if you put the question to Lucky133,he would undoubtely prefer the GTV with mol2.
Basically you cant really compare them,if i would buy another Formuler box,i would go for the GTV with android 12
Almost no problems with it.
mol3 is newer but contains bugs.
Oh, well, on the contrary, I have three Z11 pro max on the go with one of them BT1 edition.
I have to say, MOL3 is incredible in comparison to MOL2.
Themes
Reorder channel list
If you have more than 1 service they’re all in the same list, no need to disconnect and reconnect
I find it more fluid to use overall and I don’t appear to have the issues the many others report. We have to understand aswell that different providers have different setups which undoubtedly cause issues for some.
Remember Formuler will only have so many subs to test their software against.
I think many forget that a lot goes into mytvonline whichever version it is so patience is needed.
There really is no better app for IPTV than what Formuler provide, coupled with their boxes you have the look and feel of a cable to sat service. This explains why 99% of other Android boxes have fallen by the wayside.
Firestick days are absolutely numbered when it comes to sideloading, Amazon are 1 click away from stopping you doing it.
Mytvonline3 is a great upgrade from mytvonline2 and Formuler are doing what they can to make it the best it can be.
Sure there is the odd things that could be improved for usability but it’s minor for what you are actually getting.
I would say the most common issues most report is 24hr main epg and the long winded way to refresh (could do with a refresh option same as mol2 alongside the automated option) but overall that’s the main couple of things.
Those will rollbacks, it doesn’t affect everyone, it can depend on the users setup with buffer time set to long or short, if they are using a vpn or not etc. additionally as I said at the start, it could be to do with something the providers side of which MOL3 needs tweaking. I understand some report there’s no issue on Z10 series or Z8 etc but remember those had these issues too at one stage and eventually were sorted out. Same goes for Z11.
Maybe the Formuler team could do with a huge load of subscriptions to test against, of which provide them and see what happens.
sorry for the long post, I wanted to highlight that there’s so many variables when it comes to IPTV, it can be hard and take time to sort things out.
But in summary, Z11 series is excellent, box wise the same as previous but MTOL3 is what makes it an outstanding flagship series of devices.
And I’d be shocked if at some point you don’t see a GTV or variation of it with MOL3 on the horizon!
If you have more than 1 service they’re all in the same list, no need to disconnect and reconnect - I actually really dislike this. I was using the mol app on my telephone and it allows you to collapse your tv services so you only see the groups in that particular service. I wish I could do the same with mol 3
Sounds like i should wait for now. I don't really need it but wanted to try it. For now i will wait till more of the bugs are ironed out.
But consider you can pin channel sections and reorder them how you like.
You don’t necessarily need to have everything in one list.
Of course you can also create custom groups and have that in your list instead.
Lots of things you can do.
I see your point on collapsing groups / provider, that would be nice to see in mol3. I do believe it’s been a feature request for some time so maybe it will appear at some point.
For now, there is options and workarounds
Display More
If they bring that feature to MOL3 it would be the most complete tv application ever imo. I am hoping they do.
Something new coming to the Z11?
I prefer the look of mytv3 over mytv2 but my z11 has not been stable since I bought it at launch 1y ago,so many issues reported by the users that the only box I recommend to family is the z8 jst because it's more stable but in 2023 it's hard to recommend any formuler box as they ain't cheap and there there useless outside of the mytv app,if I try to play a movie in kodi or syncler or any other player every 1080p movie is upscaled to 4k resulting in a blurry picture when auto frame rate is enabled in any player,if you turn afr off the 1080p plays at 1080p but then you have stutter issues,there is no fix for this as formuler won't fix it,so for me £150 for a box just to use mytv is alot to ask even more with all the fw issues
advice friends the gtv.
No more questions from people were to find a corrrect working version of a app.
On gtv all working apps are in PlayStore. no more sideloading. (Except apps what not in appstore may from google)
Different experience here. I sold my z10 and really like z11 myonline 3. And got a z mini for the other place.
Z11pro max for over a year I use stalker portal and have had zero issues with the exception of Amazon Prime video app not working
. Mytv3 works great all the time
