As the description says. When i select something that requires the on screen keyboard it does not pop up.
Box Z11 pro max
I setup the box and went to setup my Wifi. after selecting my wifi I get to the password screen and I can only enter numbers with the remote. The on screen keyboard that pops up doe snot show up.
I then went to try and do a factory reset and the same thing I can only enter the pin and then can not click the check mark to continue as there is no onscreen keyboard.
I double checked the keyboard settings and they all match my other box
