Is it possible to change the EPG timeline?
Now it is set to 2 hours.
Hi, does a OTT provider work with mol3,or do you need to install an OTT player from Market,and so you cant use mol3 (and mol2 also)?
Anyone having experience with OTT provider? ![]()
It is every time I try the back button but only on live tv not noticed it anywhere else.
Log no. 00000016DCE12
The devs are checking the logs.
Meanwhile, could you try accessing 'Home screen > Settings > Apps > MYTVOnline 3' to delete the cache and check again?
Deleted Cache, no change still kicks me out. don't know if relevent but sound continues for about a second after.
Edit: Today Saturday 24th it has started working as it should very strange.
Once again, for the umpteenth time, please add an "auto-tune" or "tune channel" option when scheduling a recording.
I'm on stalker but when I have a scheduled recording that comes up, the box will stay on the channel it was and recording will begin behind. That causes rollbacks on the recording.
With this update is Not possible to add new provider and existing provider get error, in tivimate it works. Not all my provider have this issue.
Please look into it
Please look into it
Edited today one and added, so the problem is only on your side and not update depended! Do factory reset or do you have Provider Box with provider config on it?
How can I eliminate the delay on live TV?
Good question,on one of my 2 providers,there is a distinctive delay in switching between channels (AFR off!), hope somebody knows a fix for this?
Changing channels? And have 1-2 seconds black screen.
turn off afr in mol3 menu.
And also what you can try is In android settings menu find private dns at network settings. And set in on cloudfare or quad9 dns.
Restart. Should help also.
hi guys
Just kicked out of MOL3 a few times again. Just send log 0000001735717 again.
What concerns me more is the error I got (see attachment). Is this known, why does this occur and how can this be avoided?
(I've seen this a few times in earlear firmware versions, so this isn't new)
When this happens, do factory reset. If it happen again after factory reset, then you need to use your warranty and contact the seller.
I have almost 30 seconds of transmission delay, for example in a football game on normal TV the game has already started, on mytvonline3 is yet to start
Thats perfectly normal and one of the quicks of IPTV ![]()
Quickest is satellite, then Cable and then comes IPTV.
Tip: in MOL3 is "Skip Ahead" feature for such things, the Buffer should be full for this. Try it.
There are still low volume issues on lot of channels after applying the new upgrade. I have the volume set to max on the 11 Pro max ...it is going through a Sony TV, which is connected to a Samsung HW-990C soundbar via HDMI connection. Is there a way to not use software sound emulation ...stick to the default hardware? Does hardware output 5.1 sound?
When I change channels, a normal image appears, goes black and returns to the normal image again. anyone with this problem?
Gathus it looks like AFR (automatic frame rate), this is normal behavior. Disable it in settings (player settings) and see if it still does it.
Any idea what you did?
I am having the same issue
iptv supplier gave me a new url, after that it worked
After applying this update, my EPG content does not automatically refresh anymore. ..I even did a factory reset and restarted from scratch ...content is not getting updated....appreciate any advice?
Hello
I've noticed since this update that the subtitle options are very limited. I've registered for the new website and I've made sure to login and clear the cache.
It looks like I can find subtitles for movies without any issues but I can't find subtitles for TV shows. Even if I do a search for Family Guy, the only results that come up are for the Family Guy movie.
Before the update I had no issues finding the subtitle I need.
Any suggestions?
For update I uninstalled MOL3 and then reinstalled it. All working fine now
I leave my box always on but today i wanted to open MOL3 and it kicked me out. Also could not get in again. Box rebooted automatically it self without any warning. Never happend before the update. Is this a bug or ?
Maybe some MOL3 process in background freeze and then came the kick. Reboot should fix it.
I got a customer did this morning the software update but now he cant switch live tv categories its stuck at 1 categorie. Rebooted few times, forced closed MOL3 but still cant switch categories. Have let him delete portal and add new portal. Works now again.
Great news.
Dont always play with cache etc.
Delete the whole app and a restart and install the app fresh, saves a lot of problems.
It sometimes happens with direct TV channels that the picture stops temporarily, chops.
If I shut down and restart it goes away.
What is it due to?
Hi, same here but with a Dali katch one soundbar via hdmi connection, i must turn it almost full open to get decent volume..
EDIT, opened the remote app and adjusted the android volume slider to almost max and now ok.
hi where is this android volume setting? I use the remote and it is max. Thanks
I have a 1Gb connection directly to the router and quite a number of the channels stutter while playing video, especially the 4K ones ... is it the 11 Pro Max box or service provider? Maybe I will try a different box from a different company to see where the problem lies but was hope to get some feedback or assistance from others on what could be causing this?
You must first open the app "formuler remote. Choose your remote and choose volume etc.
You use our Box and Provider is Never Formuler (Is global Info for all)! Provider is someone where you get your subscription.
Test other Provider instead other Box! Formuler Boxes are the best for this.
You use our Box and Provider is NEVER Formuler! Provider is someone where you get your subscription. Test other Provider instead other Box! Formuler Boxes are the best for this.
Is it not possible that the guy meant his Internet Service Provider (ISP),instead of iptv provider,as he is referring to his 1GB connection?
Most Formuler users are in a way addicts,as they always buy more boxes after the first experience with them,and they dont feel the need to try out other brand boxes!
I think he will tell us soon enough what he really mean, ISP or Provider ![]()
BTW: Only for Information. When i post, i post also sometimes things that are not only for the post i answer, sometimes are Global infos also included and those are for all users who read later.
The Info about Formuler is never Provider, is such extra global Info. You will not believe how much users asking us for sub. renewal instead to ask they Provider ![]()
Hope you understand now my way of posting.
Same here. I have to manual update EPG , Thoughts? Thanks
my apologies if i mix up terms ...just trying to trouble shoot the issues i have been having and really appreciate the support ![]()
I have reset the Zpro 11 Max ...and EPG manually have to be updated. Then I deleted MOL3, reinstalled but still EPG content has to be manually updated. Any other way to fix this issue? It use to automatically refresh. Thanks
hi
I can't check right now, but what EPG update interval setting do you have (go into content manager and you can change this in each portal separately - I'm using XCAPI)?
hi
EPG setting is for 7 days keep and refresh everyday at 5am. I am using the Default EPG but did try the Alternative ...found similar results.
