2 issues, Epg and Recording
  • Hello,
    I'm getting 2 issues with my z11 pro obviously using the Mol3.
    Firstly the epg, i can kind of live with the fact of not really getting more than 24hrs worth of list. (But I would like it to go further). Nearly every day, when i load up the mol3 all 3 of my provider's list "no info" on the guide and on the single channel guide, so I have to go to the content manager and manually update all the time. Gets frustrating. All 3 providers and on the default Username and Password with the epg mode set to advanced.
    Secondly the recording. I don't do advanced recordings, but if there's something starting and I think I'd like to record it, I'd go to manual record option on that channel and I get Recording error message. All providers have multiple connections and the hard drive is formatted correctly.
    Apologies for the long winded message .
    Any help would be appreciated
    Many thanks 😊
  • Firstly,we have become accustomed to the epg being 24 hours on XCAPI connection,if you want more you have to switch to MAC-ID connection and set epg mode to "alternate".
    Secondly what do you mean by advanced recordings (=scheduled recording?) What do you mean by manual recording option, OK button on grid epg or direct recording via button with red circle,below of menu button?
  • Thanks for the reply,
    provider doesn't support mac connections, so I'll have to live with it then. Just annoying that we expect newer and so called better boxes to work with all formats.
    Scheduled (advanced as i called it) recording, I don't do, but yes the manual where you bring up the channel osd bar and select the record option "Warning Recording error (1)"
  • Also my initial regarding the epg was the fact that I'm having to manually update it every time I turn the box on,
    To assist with automatic update of epg do the following:
    On any live channel
    Select menu button on remote (3 lines)
    Select content manager
    Select content sources and choose your subscription
    Then across where you see log in details etc, above are some icons. Choose EDIT (looks like a pencil)
    Then go to epg update interval and change to 24 hours or whatever you find suitable.
    That should then automatically search for epg when that time hits.
    select update to save it.
    Overall it won’t change that you’ll only get 1 day epg but it should refresh it automatically to save you manually doing it.
    It works well for me so hopefully it does for you also.
    Actually, it appears to be a subscriber service offering (re: your 24 hour only guide on XCAPI) rather than a Z11 shortcoming. One of my Subs is an XCAPI and they supply 4 days of guide info.
    Cheers!
  • Actually, it appears to be a subscriber service offering (re: your 24 hour only guide on XCAPI) rather than a Z11 shortcoming. One of my Subs is an XCAPI and they supply 4 days of guide info.
    Cheers!
    I too have 2 providers on XCAPI,and both offer 4-6 days of epg in single view epg,however on grid epg its 24 hours or less(making it dificult to set scheduled recordings!).
    Unfortunately i cant switch to MAC as they only offer XC connection,i would be interested in your XC sub.that provides 4 days of guide info,maybe you could pm me about it,if the forum rules allow this?
    Whether or not its a Z11 shortcoming is not really relevant,but the majority of reports indicate a 24 hour guide epg on XC connection!
    Proost(= cheers in Dutch) :grinning_squinting_face:
  • goeden avond (dutch for goog evening 😆 )
    I do have 2 z10 and 2 z11.
    The z10 grid epg no problem z11 only 24 hour.
    Today switch to mac on z11 and yes between 4 and 5 days grid epg BUT yes a Big BUT only if you set epg in portal to Alternatief. If not also 24 hours.
    So its a Z11 problem.
    I think.
    Chris
  • I have the same problems with EPG and with recording.
    Although my provider gives me 2 channels, I can't record a program/show I'm not watching. And even when i record something i'm watching, the record is f*cked up: recording cuts in the middle of the show or freezes or do weird stuffs.
    I've read that some users switched from MOL3 to another soft (but don't know which one) and that fixed pretty much all their recording problems...
    Anyone tried ?
    Regards.
    Anyone tried ?
    Regards.
    You should read the posts by gabi,who solved his recording problems by usingTivimate instead of mol3.
  • You should read the posts by gabi,who solved his recording problems by usingTivimate instead of mol3.
    Ho, thanks, I didn't know he used Tivimate. Was about to PM him to know...
    I'll try Tivimate, then.
  • Ho, thanks, I didn't know he used Tivimate. Was about to PM him to know...
    And I did two simultaneous recordings today (superposed most of the time, in fact) one via MOL3 and the other one via the other app (two sources combined in one m3u via IPTVBoss). Worked flawlessly. I’ll also try two simultaneous/superposed recordings (also MOL3+the other app) from the same m3u but this time from only one source (2 connections source). I think it’ll work without any problem since the only limiting factor is (should be) the internet connection. It would be so great if the MOL3 programmers would implement this for us not to have to resort to other apps… My only hope is that these results will NOT “inspire” anyone to block this workaround. And cheers henkie ! :smiling_face:
  • And I did two simultaneous recordings today (superposed most of the time, in fact) one via MOL3 and the other one via the other app (two sources combined in one m3u via IPTVBoss). Worked flawlessly. I’ll also try two simultaneous/superposed recordings (also MOL3+the other app) from the same m3u but this time from only one source (2 connections source). I think it’ll work without any problem since the only limiting factor is (should be) the internet connection. It would be so great if the MOL3 programmers would implement this for us not to have to resort to other apps… My only hope is that these results will NOT “inspire” anyone to block this workaround. And cheers henkie ! :smiling_face:
    Thanks for that feedback !
