I miss one button on my Formuler GTV-BT TV-IR Control
I would like to switch HDMI ports on my Samsung TV. Is this possible to add it ?
I dont think it is a matter of missing one button on your remote,but more a matter of programming the extra buttons that you can "toggle",I do not have a BT remote nor a Samsung tv,so i can only offer you the advice to install remote app from market and try to find out if swiching HDMI ports is a option.
hi
I'm following here ...
But afaik the GTV-BT1 can't be programmed - although on https://www.formuler.tv/gtv-bt1 there's: Universal TV Control Use the Formuler Remote app to program your BT1 remote and control your digital TV. Most major TV brands supported. Control the TV Power, Source, Volume, Menu, and more ...
That's the whole issue. The remote app was automatically installed at start-up but the remote cannot be programmed, although it could be me. Pressing the TV button on the remote should bring it into the programming mode. No joy! Nothing happens. So yes, still missing the button
Your issue would be best answered by F175n,who i regard to be the specialist on remote issues
Hi Henkie,
Do you have a suggestion how to get in contact with F175n? I don't find him/her in the members list
He is second on the member list as 175n Formuler Evangelist, i would not contact him directly,but wait untill he is online,as most of his answers have a note,something like "unsollicited requests for support by pm will not be acknowledged,all communication via Forum"
Just be patient when he picks up your issue,or wait for an answer by SAM.
1. Please do not disturb 175n with any support questions, he will answer when he have time, or think he should do it but he do not need to answer anything, there are staffs for this. He is the Boss here and communicate from time to time with us! So please do not recommend such things even if it is well-intentioned Thank you.
2. Questions can be posted here in Forum and if not correctly answered or no solution, open Ticket on Formuler Support site.
3. For programming the RCU we have two solutions (IR Mode RCU<->TV RCU) on backside of the Remote. This will only work if the TV Remote is not Radio Controlled RCU and in some cases like LG and Magic Remote the connection between TV and TV RCU must be first cut to be programmed with IR1-BT1.
Second. For extra buttons there is Formuler Remote App so you can program Hotkeys.
And last, i m not sure if the HDMI switch Button code from TV RCU in specific case like this, can be cloned to some Formuler RCU button. Some TV Models have static button and this can be then done only with original TV Remote. Try method 3. and if this doesn`t work then it`s not possible.
