I just bought a new Z11-PRO MAX from a friend and with it I have a GTV-IR1 v3 remote control
I can't get it to work on any of my 3 Formuler boxes (Z8-Z10-Z11)
If I use one of the other two GTV-IR1s that I have it works everywhere.
So I guess it's the remote control that's the problem.
I noticed that on the two that work when I click on any button the light is white while the one that doesn't work the light is red.
So I was wondering if you wouldn't have any idea what's wrong with this remote control.
I checked a bit on the net but I didn't find a solution.
It says that to reset the remote control you have to click the OK & MENU button at the same time but I can't find the menu button. I tried different buttons without any positive result.
I saw on the forum to check with a camera to see if I could see the infrared light. On the remote controls that work I see a pink circle when I click on a button and on the one that does not work I see red signs but not clear. So is it because it would have remained in TV pairing function if yes how to change that.
Thanks for your help!
Guy
