Having problems with MyTvOnline3
  • I'm new at this. I'm having problem with my Z11 pro max and MyTvOnline3.
    I get two different messages on certain channels ''Please try again later. An error occurred : ParserException''and ''Please try again later. An error occurred : UnrecognizedInputFormatException''
    Also a lot of my channel in my EPG with ''No Information''
    I tried to read all the threads to see if I could find an answer to the problems The only thing I found was to delete the app MyTvOnline3 and re-install it, wich I did, but it didn't fix the problems and since I re-installed it the tvseries and the vod play in french even if everything is set to english
    I did a Reset factory but nothing changed
    Could you help me
  • Hello Lath,
    which connection are you using with your Provider (XC Api, Stalker MAC/ID or M3U Playlist)?
    Do you have also possibility to test other Provider, like trial 24h and compare if same happens? Because so much issues at once, point to Provider sub.
  • Hello Lath,
    Using XC Api with an ID and PW and about the provider I have two other boxes Z11 Pro and MyTvOnline3 with each a different code of course and everything is fine other thand the ''no information'' on certain channel. All the rest is A1.
