Hello
Currently with a Z7+ that bugs quite a bit, would like to have your opinion on these two modèles.
A switch to a Z10 pro or directly to the Z11 ?
Thank your ![]()
Hello
Thank your ![]()
Hi,i have both boxes z10pro and z11promax.
Since the big update,last summer,my z11 works nearby perfectly.
I would go for the z11,bon chance![]()
Hello
Thank your
Z11.
It has the androidtv playstore so all apps you download via playstore works like a charme on your box.
No mouse needed
Thanks to you., in my search came across the G5V formuler, anyone know ?
Yes, Lucky13 knows all about GTV,he is a big fan,i have no experience with this box
OK thanks
OK thanks
Gtv is a very good choice my friend.
Androidtv software, mytvonline 2 and a upgrade from android 10 to 12.
Also bluetooth remote. Have him for years and very happy with it.
Z11 is also very good.
Its up to you my friend.
Thank you.
Now we'll have to make up our minds
I have all 3, Z10 Pro Max, Z11 Pro Max and GTV.
Z11’s Mytvonline 3 by itself is worth going with it. Once you try it, you can’t go back to tvonline 2.
If I could, I’d replace the other two with Z11.
My 2c anyway.
That's why I'm giving myself time to think about it
In the mean while also have a look on You Tube for reviews of Formuler boxes![]()
I own a Z7+, it would be to have a more interesting model. Will a Z11 pro be enough
More then enough😃
I'm going to look for an opportunity
There are worlds between this two Boxes. For you it will be completely new experience.
