M3U Playlist users.
  • Hi All
    First I would like to say that when I spend 150€ on z11pro I was thinking that it's the best box on the market.
    But after a a while I think that I flush my money in the toilet, I really think that box as well MOL3 is the best thing "you" can get but the thing that MOL3 is not supporting customers that's using basic M3U playlist it makes it just a android box as many other one's cheaper on the market.
    To get everything that my provider offer I need to have other iptv app installed.
    I know that Api offers better quality of epg and other things, but for persons like me better epg gives nothing If I even can't watch anything from archive that's my provider offers.
    I really tried multiple apps and all the time was waiting for MOL3 because it's still the best, but year have past and basic M3U users are still not relevant for formuler team, that's real shame.
  • To get everything that my provider offer I need to have other iptv app installed.
    Then let MOL3 convert your m3u Playlist into XC Api Portal and you will get what you need, much more benefits than with any m3u playlist.
  • Hi,
    Hi Sam
    I have read I think all topics for that.
    For example this thread
    Ilias
    April 29, 2023 at 2:56 PM
    Over here it says about converting m3u playlist but don't really "say's" how to do that.
    Then it's also this thread that's I would say is my issue
    offenbach
    February 20, 2023 at 8:16 PM
    and from that thread I have understood that without creating some servers and fighting with my playlist I cannot make MOL3 my iptv player. What is really poor for tool that's cost 150€ especially when I have read that older version on formuler didn't make such problems with m3u playlist.
    So that's why I was waiting so long time with hope that something will change.
  • If you gointo mol3>settings>convertplaylist to Portal,you shouls be able to do so,thats how to create XC Portal:smiling_face:
  • I actually have that option turned on and still nothing new in my subject:pensive_face:
    Maybe you should toggle the button a few times between on/off ?
  • Maybe you should toggle the button a few times between on/off ?
    Small Update.
    Have tried as you suggested, nothing changed. Also have deleted playlist and uploaded new one in fact tried several playlist from my provider with no effect.
    On other app's archive work without problem and I can't use MOL3 because formuler staff don't care about m3u playlist users.
    Really shameful 😕
    Have also tried to create stalker portal but this id beyond my knowledge.
  • Ok, once again from start because this is new for you.
    Long M3U Playlist url is known and you have it but we want to create with same data from your m3u url, one XC Api portal with login.
    Your url look like in this example: "http://provider.com/get.php?userna…_plus&output=ts"
    First deactivate in Content Manager your current Playlist (4th icon from left).
    Now, what you need to do is only add new portal (no playlist) with login, the part with "login required" have to be activated -> after url insert!
    Url for example (see your m3u url) : http://provider.com
    User ID (is the username, see your m3u url): 11111
    Password (see your m3u url): 22222
    For stalker you have to register your MAC ID with Provider so they can activate your sub on it, how ever also for this have to be added new Portal and the url they give you.
  • All that I know.
    Before I start thread I read everything I was able to find. And that I placed in my second post in this thread.
    As I said my url with playlist don't provide username or password.
    It's a url with token so I can't convert it to xtream. Like I have write in my second post in this thread.
    But let's make it easier for you to understand that.
    Url to my playlist looks like this
    https://my.tele.com/play/hls/custom/95347/sD953hfh685ncfh
    Of course that's just an example not real link to playlist.
    So now convert that into XC Api.
  • But let's make it easier for you to understand that.
    Thank you for your education and sorry if i want to help but not read your second post (RE: M3U Playlist users.), where by the way nothing stay about missing user and password !
  • Thank you for your education and sorry if i want to help but not read your second post (RE: M3U Playlist users.), where by the way nothing stay about missing user and password !
    I am grateful to you for trying to help.
    And you are right in the second post it doesn't say that I don't possess a username and password but I was able to find out on my own that if there's a word "play" or "token" in the url then it's impossible to create XC Api and also assumed that Fromuler Staff knows that. And about word "play" I have mentioned when I was answering to user henkie few posts up.
  • Then let provider change your account into MAC/ID. On bottom are box label, share the ID starting with 00:1A:79: with Provider and let them create stalker account with that ID. They will give you new url. For example http://xxxxxxxxx.com/c
    Create new Portal and include the new url, should work instantly.
  • Yes MOL3 is not the best player for m3u. If you use it to watch SamsungTvplus is ok,but for PlutoTv mol3 jam when the TV programming goes to a advertise of 2 mins. You need to go back and forward with channel down and up on the remote before you can continue to listen your tv program. I here I use Tivimate for second m3u player. I hask to the team to put a fix to MOL2 because some channels on a french playlist stay in black(no picture) with sound only. For those z8 box i use Tivimate too. Tivimate is more stable and have undreds of fonctions and very complete. I can attribute a EPG link to one or more channels they can't get epg. If you want to test french channels in my contry i can give you a free links. :smiling_face:
    Stay Tune,Return after the EPG LOAD! :smiling_face_with_sunglasses:
    Nvidia...Tivimate...good choice!
