what is the main differences between the Z11PRO and the Z11PRO MAX, is it a great difference please
what one please
- Z11 Series
- Hardware
wullboy -
April 29, 2025 at 7:51 PM
Feature
Formuler Z11 Pro
Formuler Z11 Pro Max
Processor Quad-core Cortex A55 Quad-core Cortex A55 RAM 2GB DDR4 4GB DDR4 Storage 16GB eMMC 32GB eMMC Wi-Fi Dual-band 802.11ac (Wi-Fi 5) Dual-band 802.11ax (Wi-Fi 6) Audio Support Dolby Digital Plus Dolby Atmos and DTS-HD Remote Control Standard IR remote Optional BT1 Bluetooth Voice Assistant Remote Operating System Android 11 Android 11 Media Platform MYTVOnline3 MYTVOnline3 GPU Mali-G57 MC1 Mali-G57 MC1 AV1 Decoding Yes Yes Ethernet Gigabit Ethernet Gigabit Ethernet Bluetooth Bluetooth 5.0 Bluetooth 5.0 Dimensions 105 x 105 x 21 mm 105 x 105 x 21 mm -
Thanks my friend adrilang .
I have z11 pro max 11 bt1.
I thought all z11 were same with sound. Only z11 pro less "storage".
Thanks for refreshing my mind.
Here’s what I’ve got to include mini, hopefully accurate
Feature
Formuler Z Mini
Formuler Z11 Pro
Processor (CPU) RealTek RTD1325 Quad-core Cortex A55 Quad-core Cortex A55 GPU Mali-G57 MC1 Mali-G57 MC1 Mali-G57 MC1 RAM 2GB LPDDR4 2GB DDR4 4GB DDR4 Storage 8GB eMMC 16GB eMMC 32GB eMMC Operating System Android 12 Android 11 Android 11 Media Platform MYTVOnline3 MYTVOnline3 MYTVOnline3 AV1 Decoding No Yes Yes Video Output 4K @ 60fps 4K @ 60fps 4K @ 60fps HDR Support HDR10+, HLG HDR10, HLG HDR10, HLG Audio Support Dolby Digital & DTS Dolby Digital Plus Dolby Atmos, DTS-HD Wi-Fi Dual-band 802.11ac (Wi-Fi 5), 2x2 MIMO Dual-band 802.11ac (Wi-Fi 5) Dual-band 802.11ax (Wi-Fi 6) Bluetooth Bluetooth 5.0 Bluetooth 5.0 Bluetooth 5.0 Ethernet Not available Gigabit Ethernet Gigabit Ethernet Remote Control GTV-BT1 Bluetooth Voice Remote Standard IR remote Optional BT1 Bluetooth Voice Remote USB Ports 1 x USB C 2 x USB 2 x USB DRM Support Widevine L1, L3 Widevine L1, L3 Widevine L1, L3 Dimensions 83 x 60 x 12.5 mm 105 x 105 x 21 mm 105 x 105 x 21 mm Power Supply 5V DC / 1A 12V DC / 1A 12V DC / 1A -
Hi Adrilang,
where are this data from? Z Mini data seems are not correct.
Hi Adrilang,
I knew it! I had my thoughts about it.
Edited, does that seem
More accurate?
If there’s inconsistencies please feel free to free to point out as I’d like to make the post accurate and as such will edit accordingly
More accurate?
Hi,for z mini you state ethernet not available,it is however possible viaUSB adapter,so the option is there
It’s showing standard out of the box info really. But yes quite right, with an adapter it can have Ethernet and of course storage
When you look deep at the specs for both, there are only 2 differences. 2G of ram & 16G of storage on the Pro & the Pro Max has 4G of ram with 32G of storage. CPU processor & GPU are both exactly the same on both.
