Everytime I start up my z11 pro my remote stops responding,I cannot change channel etc,so i have to pull out mains supply many times for it to respond,Iam so fed up with this Iam thinking of going back to the f/stick just for peace of mind.Any advice please
remote problem with z11 pro
- Z11 Pro-BT1
- MYTVOnline3
gordon -
January 18, 2025 at 1:31 PM
Please tell us how you use the remote in IR or BT mode, is also maybe the optional IR Eye in use?
When the box starts , how flash the led light on the remote when you press some button?
is this a new remote that came with the box or has it suddenly become unresponsive, try another remote, there not that dear to buy m8
Every button i press the light flashes but the box does not respond,btw,thank you for the replies.
Flashes how? Red, Orange or white? You labelled it as BT1 Remote with Z11, so it must be the BT1 remote.
Check how to:
Please provide a picture of your remote, and let us know the color of the LED light (on the remote) when pressing a button.
Hello. The problem was solved? I'm having the same issues. The remote freezes, and I can't do anything. I pull out the energy cable, and put it back. Same situation.
A few hours without the energy cable, I test again, and then starts to work.
When this happens, I click in the remote buttons, and all the colour lights appear. I even try to pair again the remote, the light blinks, but doesn't happen anything.
This as happen to me three times.
When works normally, I always check if there's any update to do, and it's everything ok.
How did you solved it?
Thank you
Delete your remote from bluetooth menu.
I do think you have the bt1 remote?
so hold 0 (zero) and OK button till led blinks for reset the remote.
then go to bluetooth menu in settings and search for bluetooth devices. and hold OK + menu button couple of seconds and see if led blinks and the box find your remote again.
Try also with new batteries!
I have the same problem.
Sometimes it seems to be unconnected.
Then it will only turn on and off my tv, but the box connection is lost.
everytime i need to take out the batteries and reconnect the remote.. -
everytime i need to take out the batteries and reconnect the remote..Next time it happens, open the formuler remote app and select the BT1 remote from the remote selection list and share a photo of the remote status screen.
Also make sure your remote has not been switched to TV mode. Press and hold the TV/STB button on the remote for 3 seconds to toggle the mode.
everytime i need to take out the batteries and reconnect the remote..As mentioned by 175n. Your remote is in tv mode. That's why you can turn the TV on and off.
You long hold the top left button. Flashes red it's TV mode. Flashes orange it's in Formuler mode.
Taking out the batteries and putting back in this puts the remote back into Formuler mode.
Probably the number one question I get weekly.
I still have same issue since last year and still not resolved, when I can connect the remote through bluetooth (freezes and random keystrokes) infrared mode works pefect. Please Formuler staff send me a remote for TESTING purpose and feedback so we can come to some conclusion on this topic, is it the remote or is it something with the Z11 Pro Max?!? If it’s the remote I will gladly pay for a new one!
Please check your inbox
UPDATE: The issue was the remote not the box. New remote solved the issue. Thank you very much!
Great to hear.
Goodday my friend
