Hi, i just swop iptv provider but cant find the section to add the portal? Very strange. Hope anyone can help
Molcfg clearing tool.
- MYTVOnline1
- Rene
Enter the MOL, menu key, service option, edit list and enter the nickname, url and inform the provider the MAC address.
Problem I have no service option? I have live tv, vod, settings. It says reload portal, yes but dont see where it can put the urls down...
Ttry to put a new mytvonline link on start screen and open it, then you will see service option, after enter Menu. -
How to add a new mytvobline link?
What happens if I do a hard reset?
Hard reset= box goes back to state it was when left factory. You can do it. Then try loading portal info
Send us pictures of what you’re seeing because to be honest, it’s very self explanatory about how to add a new IPTV link to a portal.
Sorry. - Attached some photos, absolute no clue how to add a new iptv link or a new portal??
I deleted the mytvonline app and downloaded again but same problem. An other ways I can watch my iptv? Other app??
Menu then select portals then edit portal
So what freedom35 said is correct.
That is unless you have a ‘provider’ box and not a retail box. Far majority of us have retail box. ie it’s straight from the factory so to speak, running the original software and what not. Provider boxes are modified slightly, and not as ‘open’. In that first pic where it shows live tv, VOD, and settings, so you not also have something called portals? I suspect not.
Does your IPTV provider come from the dude who sold you the box?
So to fix, a few things could work. Get in contact with the guy who sold you box and ask him for a code/pin to change box from provider to retail. I suspect you’ll need this code to do a factory reset (I think).
Another option could be, do you have an app installed call market or market place? If so, go there and try to download MYTVONLINE. Maybe you can download the ‘retail’ version of the app. Not sure about this though
That ‘guy’ provided iptv for 2 years but he stopped last month so found another iptv provider but struggling as above.
Shall I get a new box, formuler again? Or is another brand good as well?
Formuler Z7+ is best box out there for IPTV in my opinion. I got mine from amazon
Hello i have the same pb i want to unlock the provider thing i can't edit my portal please mr sam may i have the config tool to fix it thank you
Do you have same problem like Rene? No way to edit or insert new portal? Something else also closed?
yes mr sam the same pb as rene no acces to edit the portal or insert a new server
Ok, will upload later one file for execution and get the box into factory state.
● Unzip molcfg folder in USB root. (formatted fat32)
● Insert USB containing molcfg folder into STB and wait for confirmation popup.
Info: Files are already set for clearing.
