How can i change dns on my z8 im connected by wifi does it have to be connected by ethernet cable?🤔
Change dns on z8
Network>IP settings
Have gone into network do i now select static or dchp?
If i go into static all it comes up with is ip address
Yes static and then go to next or ok and it will take you to the next setting.
No option for that as soon as i select static it comes up with keyboard
Don't know what you are on about. Provide me with more details.
When the keyboard is visible on screen during this configuration the keyboard does overlap the next button so you can't see it.
Firstly double check the ip address that it automatically assigned in the ip address field is correct, every time I have configured this the ip address is not in the correct range. Once you're sure you have the correct ip you just have to select the enter button on the keyboard to progress to the next screen (maybe twice on the enter button sometimes) then continue the ip range for your router/gateway then chosen dns address's 👍
If the default on-screen keyboard is too big, try switching to the supplied TV Keyboard
