Hello. How to run EPG from a m3u line of the mytvonline2 application? I've never been able to run the EPG on a number of services I've had
Work EPG
You need extra link/url under same m3u connections for epg xml to work. Ask your provider to give it to you.
how do I access the storage to put the gz file? I tried to access the folder and it appeared to say empty storage
my Provider has provided the link but still does not give. is the only application that does not work
Create on your USB Stick file folder "M3U" and copy the file inside. Then under connections lead mol2 to this file.
You should unzip the gz file and use the xml file instead.
I did exactly as I said but it still did not work ... I never got the EPG to work either MOL1 or MOL2 ...
Check EPG offset. If the offset is wrong, the EPG could appear to be empty because it is shifted off screen.
Also, you really need to be using the download URL for the xmltv file. The local file you are using is probably already too old.
Right, forget to write this.
I use m3u link with epg link through XE. Works perfect.
