Greetings,
I just updated my z7+ firmware and rebooted now my mol app isn’t opening it checks update but says fail to install update. 2.0.4
Greetings,
Hi Marko,
What you mean with 2.0.4? Is unknown because last updates are less then 2.0. Or you mean Update App?
Please upload screenshot.
Yeah all fixed had my SD card has default I had to go to my settings and make my internal flash drive has default it was trying to update but failed to install but it’s all good now and yes I’m buying the new z8 the z7+ has been good to me very impressed with the device best on the market
I also have a 2.0.4 update on both a Z+ and a Z7+. Removing the SD card didn't fixed it.
Screenshot: Update 2.0.4 on Z+
A factory reset solved but the update still showed 2.0.4. Think it it's the system update and not MYTVOnline.
2.0.4 is version from the Update app and not from Firmware or Mytvonline App!
