It's down to to a combination of later security on xc panels and the speed that mytvonline Mac's switch between streams. Basically the box is reacting faster then the panel so the panel assumes you are watching numerous channels at once ( restreaming / multi line watching ) and the panel instantly blocks the line
ip blocked
Diagnosis is almost right but the problem is not the box, the problem are the settings from providers. The Formuler Boxes could zapp in 0.3sec if the Provider would support this speed and their is also the ISP network. Some bigger providers have understand in last time that the need for faster data delivering is necessary and lowered the security script values, with such providers the box works very well.
Only few others don`t care and let the security value on high level and here begins the problem with ip block in some cases.
I don`t think the Users would be happy if Formuler comes and downgrade the speed of formuler boxes to lower level, providers should look forward and come to same standard and not to do what they like.
The devs should fix the way epg populates on Mac portal. I am forced to use m3u instead of Mac portal because the EPG populates only when you press the epg grid button on the remote and then you have to scroll through the whole channel group list to populate the EPG. While on m3u and XC EPG auto generates in the background without doing anything that I mentioned before. Works much better
Improvements are coming. We can only do so much with the data that is provided by the service side.
And if we request the data too quickly (for user's benefit) the banning begins again.
But those in the know already know about the fatal flaw in the mac portal protocol that is the cause of all of these issues in the first place.
