Hi guys...
I’ve had a look at other post however can’t see anything that matches my issue. Sorry if I’ve missed something and duplicated something.
My issue is since the latest update (beta version) I’ve had buffering issues. When I press the info button the signal bar only shows between 1-2 blocks..before it was always full.
When I change channel it changes straight away however after a couple of seconds I get the loading wheel and then connects. I’ve resorted to going into mytvonline and changing the buffering time to 7 seconds.
If got fairly adequate download speed that averages out at around 35meg so should be more than enough to run as it did.
Any help would be appreciated 👍🏻
Sorry forgot to had I’m on the Z8 😊
