Hi all,
I have recently aquired a F4 Turbo w/ DVB-S and DVB-T/C tuner.
Currently only DVB-C is needed, satellite will follow.
I live in Munich / Germany and I am using Vodafone Kabeldeutschland DVB-C network.
The installation and signal is fine, my TV and other receivers can receive all available DVB-C channels flawlessly.
However ... the F4 turbo does not find any DVB-C channels.
I have already tried all possible combinations of tuner setup and manual / automated scan procedures.
I have tried openhdf and openatv in different versions (including latest builds).
During scan the logfile basically looks like this
11:09:26.4720 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
11:09:26.8674 [ ] dvb/frontend.cpp:727 openFrontend [eDVBFrontend] m_need_delivery_system_workaround = 0
11:09:26.8676 [ ] dvb/frontend.cpp:729 openFrontend [eDVBFrontend] opening frontend 1
11:09:26.9212 [ ] dvb/dvb.cpp:2415 getDemux [eDVBChannel] getDemux cap=00
11:09:26.9214 [ ] dvb/dvb.cpp:1103 allocateDemux [eDVBResourceManager] allocate demux cap=00
11:09:26.9215 [ ] dvb/dvb.cpp:1279 allocateDemux [eDVBResourceManager] allocating demux adapter=0, demux=0, source=-1
11:09:26.9217 [ ] dvb/demux.cpp:90 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
11:09:26.9261 [ ] dvb/frontend.cpp:3112 tune tune tuner 1
11:09:26.9264 [ ] dvb/frontend.cpp:3058 prepare_cable frontend 1 tuning dvb-c to 338000 khz, sr 6900000, fec 0, modulation 5, inversion 2
11:09:26.9265 [ ] dvb/dvb.cpp:1887 frontendStateChanged [eDVBChannel] OURSTATE: tuner 1 tuning
11:09:26.9479 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 160 1
11:09:26.9757 [ ] dvb/frontend.cpp:2029 tuneLoopInt [eDVBFrontend] [SEC] tuner 1 setVoltage 0
11:09:27.0188 [ ] dvb/frontend.cpp:2543 tuneLoopInt [SEC] tuner 1 newTunertype 1
11:09:27.0613 [ ] dvb/frontend.cpp:3744 changeType [eDVBFrontend] data 1
11:09:27.0615 [ ] dvb/frontend.cpp:3780 changeType [eDVBFrontend] m_need_delivery_system_workaround NOT active
11:09:27.0617 [ ] dvb/frontend.cpp:2131 tuneLoopInt [SEC] tuner 1 startTuneTimeout 5000
11:09:27.0619 [ ] dvb/frontend.cpp:2124 tuneLoopInt [SEC] tuner 1 setFrontend: events enabled
11:09:27.0630 [ ] dvb/frontend.cpp:2571 setFrontend setting frontend 1 events: on
11:09:29.4090 [ ] dvb/frontend.cpp:1081 feEvent [eDVBFrontend] (1)fe event: status 0, inversion off, m_tuning 1
11:09:32.0619 [ E ] dvb/dvb.cpp:1915 frontendStateChanged [eDVBChannel] OURSTATE: tuner 1 failed, fatal
11:09:32.0620 [ ] dvb/scan.cpp:316 nextChannel [eDVBScan] no channels left: 0 scanned, 1 unavailable, 0 database.
11:09:32.0657 [ ] dvb/db.cpp:1246 renumberBouquet [eDVBDB] Renumbering...
11:09:32.0696 [ ] dvb/db.cpp:777 saveServicelist [eDVBDB] ---- saving lame channel db
11:09:32.1305 [ ] dvb/db.cpp:985 saveServicelist [eDVBDB] saved 103 channels and 1376 services!
11:09:32.1621 [ ] components/scan.cpp:34 scanEvent [eComponentScan] scan done!
11:09:35.2748 [ ] dvb/frontend.cpp:930 closeFrontend [eDVBFrontend] try to close frontend 1
Display More
or like this
15:00:32.2631 [ ] dvb/dvb.cpp:1410 allocateChannel [eDVBResourceManager] allocate channel.. 044d:0001
15:00:32.2633 [ ] dvb/frontend.cpp:3546 isCompatibleWith m_dvbid:0 m_slotid:0 type:1 types:2 m_enabled:0
15:00:32.2641 [ ] dvb/frontend.cpp:727 openFrontend [eDVBFrontend] m_need_delivery_system_workaround = 0
15:00:32.2643 [ ] dvb/frontend.cpp:729 openFrontend [eDVBFrontend] opening frontend 1
15:00:32.3168 [ ] dvb/frontend.cpp:3112 tune tune tuner 1
15:00:32.3169 [ ] dvb/frontend.cpp:3058 prepare_cable frontend 1 tuning dvb-c to 338000 khz, sr 6900000, fec 15, modulation 5, inversion 2
15:00:32.3171 [ ] dvb/dvb.cpp:1887 frontendStateChanged [eDVBChannel] OURSTATE: tuner 1 tuning
15:00:32.3173 [ ] dvb/pmt.cpp:1074 tuneExt [eDVBServicePMTHandler] allocate Channel: res 0
15:00:32.3175 [ ] dvb_ci/dvbci.cpp:905 addPMTHandler [eDVBCIInterfaces] addPMTHandler 1:0:1:6DCB:44D:1:FFFF0000:0:0:0:
15:00:32.3221 [ ] dvb/dvb.cpp:2415 getDemux [eDVBChannel] getDemux cap=00
15:00:32.3223 [ ] dvb/dvb.cpp:1103 allocateDemux [eDVBResourceManager] allocate demux cap=00
15:00:32.3225 [ ] dvb/dvb.cpp:1279 allocateDemux [eDVBResourceManager] allocating demux adapter=0, demux=0, source=-1
15:00:32.3226 [ ] dvb/demux.cpp:90 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
15:00:32.3796 [ ] dvb/frontend.cpp:2029 tuneLoopInt [eDVBFrontend] [SEC] tuner 1 setVoltage 0
15:00:32.4259 [ ] dvb/frontend.cpp:2543 tuneLoopInt [SEC] tuner 1 newTunertype 1
15:00:32.4674 [ ] dvb/frontend.cpp:3744 changeType [eDVBFrontend] data 1
15:00:32.4676 [ ] dvb/frontend.cpp:3780 changeType [eDVBFrontend] m_need_delivery_system_workaround NOT active
15:00:32.4678 [ ] dvb/frontend.cpp:2131 tuneLoopInt [SEC] tuner 1 startTuneTimeout 5000
15:00:32.4680 [ ] dvb/frontend.cpp:2124 tuneLoopInt [SEC] tuner 1 setFrontend: events enabled
15:00:32.4691 [ ] dvb/frontend.cpp:2571 setFrontend setting frontend 1 events: on
15:00:32.4697 [ ] dvb/frontend.cpp:1081 feEvent [eDVBFrontend] (1)fe event: status 0, inversion off, m_tuning 1
15:00:33.7050 [!W!] dvb/frontend.cpp:1788 readFrontendData [eDVBFrontend] Slow ioctl 'FE_READ_STATUS', potential driver issue, 898ms
15:00:37.4680 [ E ] dvb/dvb.cpp:1911 frontendStateChanged [eDVBChannel] OURSTATE: tuner 1 failed, retune
15:00:37.4681 [ ] dvb/frontend.cpp:3112 tune tune tuner 1
15:00:37.4682 [ ] dvb/frontend.cpp:3058 prepare_cable frontend 1 tuning dvb-c to 338000 khz, sr 6900000, fec 15, modulation 5, inversion 2
15:00:37.4684 [ ] dvb/dvb.cpp:1887 frontendStateChanged [eDVBChannel] OURSTATE: tuner 1 tuning
15:00:37.4686 [ E ] dvb/pmt.cpp:116 channelStateChanged [eDVBServicePMTHandler] tune failed.
15:00:37.4696 [ E ] service/servicedvb.cpp:1207 serviceEvent [eDVBServicePlay] DVB service failed to tune - error 1
15:00:37.4735 [ ] dvb/pmt.cpp:1027 SDTScanEvent [eDVBServicePMTHandler] ignore sdt update data.... incorrect transponder tuned!!!
15:00:37.4737 [ ] dvb/pmt.cpp:1029 SDTScanEvent [eDVBServicePMTHandler] incorrect namespace. expected: ffff0000 current: ffffffff
15:00:37.4738 [ ] dvb/pmt.cpp:1031 SDTScanEvent [eDVBServicePMTHandler] incorrect transport_stream_id. expected: 44d current: ffffffff
15:00:37.4740 [ ] dvb/pmt.cpp:1033 SDTScanEvent [eDVBServicePMTHandler] incorrect original_network_id. expected: 1 current: ffffffff
15:00:37.4742 [ ] dvb/frontend.cpp:2029 tuneLoopInt [eDVBFrontend] [SEC] tuner 1 setVoltage 0
15:00:37.4748 [ ] dvb/frontend.cpp:2543 tuneLoopInt [SEC] tuner 1 newTunertype 1
15:00:37.4750 [ ] dvb/frontend.cpp:2131 tuneLoopInt [SEC] tuner 1 startTuneTimeout 5000
15:00:37.4751 [ ] dvb/frontend.cpp:2124 tuneLoopInt [SEC] tuner 1 setFrontend: events enabled
15:00:37.4752 [ ] dvb/frontend.cpp:2571 setFrontend setting frontend 1 events: on
15:00:37.4757 [ ] dvb/frontend.cpp:1081 feEvent [eDVBFrontend] (1)fe event: status 0, inversion off, m_tuning 1
15:00:42.4751 [ E ] dvb/dvb.cpp:1911 frontendStateChanged [eDVBChannel] OURSTATE: tuner 1 failed, retune
15:00:42.4753 [ ] dvb/frontend.cpp:3112 tune tune tuner 1
15:00:42.4754 [ ] dvb/frontend.cpp:3058 prepare_cable frontend 1 tuning dvb-c to 338000 khz, sr 6900000, fec 15, modulation 5, inversion 2
15:00:42.4756 [ ] dvb/dvb.cpp:1887 frontendStateChanged [eDVBChannel] OURSTATE: tuner 1 tuning
15:00:42.4757 [ E ] dvb/pmt.cpp:116 channelStateChanged [eDVBServicePMTHandler] tune failed.
15:00:42.4758 [ E ] service/servicedvb.cpp:1207 serviceEvent [eDVBServicePlay] DVB service failed to tune - error 1
15:00:42.4777 [ ] dvb/pmt.cpp:1027 SDTScanEvent [eDVBServicePMTHandler] ignore sdt update data.... incorrect transponder tuned!!!
15:00:42.4779 [ ] dvb/pmt.cpp:1029 SDTScanEvent [eDVBServicePMTHandler] incorrect namespace. expected: ffff0000 current: ffffffff
15:00:42.4780 [ ] dvb/pmt.cpp:1031 SDTScanEvent [eDVBServicePMTHandler] incorrect transport_stream_id. expected: 44d current: ffffffff
15:00:42.4781 [ ] dvb/pmt.cpp:1033 SDTScanEvent [eDVBServicePMTHandler] incorrect original_network_id. expected: 1 current: ffffffff
15:00:42.4785 [ ] dvb/frontend.cpp:2029 tuneLoopInt [eDVBFrontend] [SEC] tuner 1 setVoltage 0
15:00:42.4789 [ ] dvb/frontend.cpp:2543 tuneLoopInt [SEC] tuner 1 newTunertype 1
15:00:42.4791 [ ] dvb/frontend.cpp:2131 tuneLoopInt [SEC] tuner 1 startTuneTimeout 5000
15:00:42.4792 [ ] dvb/frontend.cpp:2124 tuneLoopInt [SEC] tuner 1 setFrontend: events enabled
15:00:42.4795 [ ] dvb/frontend.cpp:2571 setFrontend setting frontend 1 events: on
15:00:42.4798 [ ] dvb/frontend.cpp:1081 feEvent [eDVBFrontend] (1)fe event: status 0, inversion off, m_tuning 1
Display More
I suspected an hardware issue, however
- I have another (identical) box since Amazon sent me two boxes -> same issue w/ second box
- I have plugged in a small antenna and did a DVB-T scan -> found channels
I am running out of options - no clue what to do next
any help is appreciated.
