july version.
Official FW 1.4.43 - SW 7.5.2 (17.10.2019)
- Update
- Z8 Pro - Z+ neo
SAM -
October 16, 2019 at 10:39 AM -
If you install new Firmware you are not able to restore your old backup. This means, after each firmware update you need to do backup again.
Thx, Sirocco30 for answering but i will go more into detail.
PiP option since this update and also other future options that are planned, like watching one channel and recording other, will need more then 1 line in one subscription. Some provider give the possibility to their users to have two or more lines in one sub. So yes, you must speak with your provider and let him activate one line more to use PiP in Mol2.
Does PiP also mean we can now record AND watch from 2 different providers at the same time?(my providers only have 1 ip per connection so i cannot use PiP).
Just done the upgrade and the EPG loads fine for me. Working great so far...
Hello admins
Any luck with fixing channels missing logo with new update?
Hello admins
If you are on beta sw and your channel logos are missing, yes, the new official update fixes that.
Hello.
I have a “multiroom” sub which allows me to watch on multi devices at the same time.
In this case PIP should be available to me is that correct? I’d like to record a channel and watch another...When I press and hold OK button nothing happens, is there a setting I need to enable?
I use portal login also
many thanks -
You first need to make sure your provider supports multiple streams also.
Good morning friends, I try to update my Formuler Z8 and I can not ... Load 5 or 10% and that's it ...
i'm still losing favorites after restart the box
On channel list current program name is still not showing for some channels even i go up or down on the list, but if i went to the epg all the info included the current program name is fetched .
i notice also on the epg as i said it fetch the info for the current program but for a few seconds it says no information on the current program but it knows the next program's name ( sometimes have to go up and down also there)
its not normal not to get it on the channel list but it gets everything on the epg... -
Which country are you in?
Which ISP?
Are there any error messages on the screen?
my provider does support multi streams yes. I have a dedicated app aside from my Formuler device provided by my supplier which includes this.
don’t worry; found the option.
It’s on the single epg bar, scrolled to it and it came on; working great.
Can you move the pip screen to different corners?
not that I can see. I don’t think you can do anything with except turn it off by pressing the ok button on the remote.
I tried the mouse control to see if it can be moved and it didn’t do anything.No issue for me I prefer it where it is
Thanks for the update; has there been any progress/resolution to the IP ban happening with certain providers?
dreamer
Yes, I have the same question. This is a BIG problem.
For now we did not get any complains, some improvements was made.
Did someone also noticed that since MOL 7.5.2 the active channel # is not remembered/used anymore.
After a reboot, and then starting MOL2, it opens/starts (sometimes) with a completely random stream/channel.
It is possible your provider is actively rebuilding bouquets and the "last channel" index was lost or scrambled.
Will ask the devs to check it out in any case
How i can use pip?
I don't see this function anywhere
Read older posts in this thread.
Yes same here. even if you do it in couple of minutes on your fav channel. moves down 1 to 5 channels. Also EPG downloading stays on for long time, thought it was sorted
That depends on the provider. I don't see that.
I have 3 panels and they all do that, after about 5 mins it goes away
I expected that I can set my NAS to be the standard recording and replay device after this software upgrade. How can I do that?
I agree it would be a nice feature but why do you say "this upgrade"? I don't see any mention of such functionality in the releasenotes for this version under New Features OR Fixes & Improvements.
Title for this thread should be changed to?: Official FW 1.4.43 - SW 7.5.2 (17.10.2019)
Yes, there was some change, thx.
Found a new issue in this version (issue persists across box restarts):
When SPDIF out is connected to amplifier/surround set: Changing the audio volume on/with the Z8 remote does not work on a few channels. When it does not work it means that 1% volume and 100% are exactly the same. Mute (or 0%) does always work.
When this happens you are forced to use the audio volume controls on the amplifier/surround set.
If RAW (passtrough) is chosen then this happens and you must use the AVR rcu. If LPCM is chosen then you control the volume with Z8 rcu.
Good to know.
I see RAW is a generic Z8 setting. Not per channel.
It is set to RAW. Still most channel volumes can be controlled with Z8 RCU.
Strange...?
Strange...?
No, because you control only normal sound content (check AudioTrack) and not channels with DD or DTS where the control belongs to AVR.
It shows AC3 for the ones with no Z8 control. All clarified now. Thanks.
You`re welcome
