Hello for few months now and despite the many update a bug with the replay is still not resolved
A step back, back to a previous scene.
I have the same problem with replay to mol2 , have you find a solution of this problem
is there any solution? I have the same problem since a long time. It's very annoying
Replay bug where exactly, recorded file, timeshift? We need detailed informations to reproduce the issue.
hi,
I have some problems with recorded file and when you watch a replay from the EPG. The video return 10 to 50 sec backward
Same problem here, it makes the EPG replay unuseable.
hi,
Exactly the same issue…
Same issue for me too. Whenever watching a program from the last 7 days using the replay feature from the EPG, it will constantly jump back 30secs or so every few minutes so it's just unusable.
Would be great if this could be resolved.
Hi folks,
I just had the same problem for months !
Guess what ... Try to desactivate the timeshift option in the settings of your formuler (Z8 for me). The Replay works like a charm since !
But if i activate again the timeshift option , i have the same bug with the video returning 10 to 50 sec backward.
Please let me know if my tip works for you too.
Nice day !
hi,
Thx Allsatboy for your advise but if I disable the timeshift option I could not pause a program or other that is being broadcast.
Have you another solution which allows me to keep the timeshift option which is important for me.
Kind regards.
Unfortunately, i'm still looking for a solution to have both replay and timeshift working fine together ...
But did you try my tip just for test ? Did disable timeshift make replay works fine ?
If we are many to experience the same, maybe Formuler team can patch this issue in a future release !
Hi Allsatboy,
I've just test, without timeshift it seems to work.
I've no more problems with the replay.
I hope you or the formuler team will find a solution to keep the timeshift on without any bug with the replay.
Kind regards.
Hi. I can confirm the same issue.
Latest Updates and actually started update before.
When watching catchup every few mins the frame rate will slow right down and go into slow motions sometimes along with the video skipping back around 10-15 seconds...
As mentioned this cycles every few minutes.
Programme is still watchable but can be a little frustrating.
Does the problem disappear when you switch OFF "Timeshift" on settings ?
Please, in this case could someone open a support ticket at https://support.formuler.tv and provide a detailed issue description. Please insert also the text with turned timeshift off. If necessary include also screenshots or small videos from the Issue. Thank You.
Thanks ! I'm on it ![]()
Edit : Ticket created #TS00004381
Guy's,
I have GREAT news !
Here is the answer from the formuler customer service received this morning :
The replay bug is a known issue and has already been patched in our internal builds.
The fix will be available for beta testing at the end of this month.
The official update will be released at the beginning of May.
The current work-around is to disable Local timeshift in the Settings menu of MYTVOnline2.
Thank you in advance for your patience.
Sincerely,
Formuler Support
Thanks for the update.
Looks like it’s all in hand, perfect
thx a lot Allsatboy 😊😊
new problem found. Sometimes, I have the same problem as the replay but with the live tv.
Also sometimes, the live tv show, all kind of channel, freeze, the screen became black. The only way to fix it is to change channel as and go back to the original one. Mytvonline seems to be unstable.
I can also say the same as Cyber82.
I’ve started experiencing this the past few days.
It’s like MTOL2 is dropping the connection and then reconnecting on its own after about 15-20 seconds.
There’s no change in the actual internet connection though which leads me to think it’s a bug.
For me It only happens on MTOL2 using a Z8 and not on any other device.
