Z8 Wifi Issue
  • Hello guys,
    I bought Z8 about 2 weeks ago from Amazon. I started to use Ethernet from beginning but from last 4 days I starts to use Wi-Fi. Now I have an issue.
    I did setup MyTVonline 2 app as a startup. So when the box starts it does not connect to wifi network automatically and Mytvonline2 app struggles to connect and in the corner, it is written "wait network connecting. After a minute the error pops up "Please Check your internet connection and portal Url" Code 7.
    However, if, at the same time I press exit to home and click on wifi icon then it connects to the internet and works normally. So every time I TURN ON the box wifi does not connect automatically, I need to go to the wifi main MENU and just press connect then it works and Mytvonline app also works normally. Anybody who has had this issue?
    Edited once, last by TU88 (October 30, 2019 at 4:20 PM).
  • Perhaps this is an issue with the standby-power functionality.
    How do you shutdown the box? Do you use the STB button on the remote normally or do you choose the "Power off" option?
    What happens when you use the "Power off" or "Restart" option in the Power menu?
    What if you disable the startup app so the box has a little more time to setup the wifi?
    I have also disabled startup apps on my Z8 because it was starting things to fast.
  • TU88
    Check your Router and connection to your Router Wifi. What are you using 2.4 or 5g? Each should have his own ssid.
    Did you set this up already in your Router and can connect to both of them? Use for first time only 2.4g to see if the connection to your Router stays stable.
  • I did setup MyTVonline 2 app as a startup. So when the box starts it does not connect to wifi network automatically and Mytvonline2 app struggles to connect and in the corner, it is written "wait network connecting. After a minute the error pops up "Please Check your internet connection and portal Url" Code 7.
    Sure, this happens when the Wifi Connection are not established fully.
  • Hello guys,
    Make a short video of what you have described and submit a new ticket to https://support.formuler.tv
    So I did all experiments, in fact I played whole day with this box. In all cases, wifi 2.4/5GHz does not connect until MOL2 set as startup app.
    Conclusion: without setting up MOL2 as startup app it works normal. wifi connects immediately.
  • TU88
    Yes dear, I tried with both 2.4 and 5Hz wifi. it is same in both case. so the fix is do not set MOL2 as start up app.
