what advantages or disadvantages the Z8 has over the Z7 plus![]()
Z7 Plus v Z8
Z8 has MOL2 and more space on the internal storage.
Z8
2.4G / 5.0G WiFi Dual-band - Dual Antenna
Gigabit Ethernet 10/100/1000M
Z7+
2.4G WiFi only Internal Antenna
Ethernet 10/100M
So for a few bucks more be best get the Z8.
What do you guys use to save to external storage.
What is best USB connection to use 3.0 or 2.0 ?
Usb 3.0 stick or hdd/ssd.
why dont come with a microsd ?
Because of external antenna, was no place for micro sd.
You can consider such a device (not just specifically this one):
