Help me please. My iptv was well since a long time. But few days ago no connection. Message error code 7. My Firmware v1. 4.75.
Please my English is not very good no difficult word
What can I do?
What can I do?
Did you contacted your Provider and ask him why this happen suddenly? Is your box online, tested with youtube?
Your portal URL might be changed by your service provider.
the fastest way will be contacting your service provider and get checked your connection status, portal URL, or credentials, etc.
Have you checked this article and tried one by one?
here explains all about error code 7.
Hi. First thanks for your answers..
I have contact my provider but he doesn t know. My url doesn t change. I have insert again but nothing. YouTube is good. Sometime my iptv is good but few minutes and then code error 7.i m going to read support cbp adm.
Thank too sam
Thank too sam
Did you try to update IP address?
I recently started experiencing similar. Mine occurs when turning on tv. I can see channel info but no picture or sound. My portal shows connected but still nothing. When I try to disconnect and reconnect is when I get error 7. I found each time I have to restart the Z8 and then it automatically connects to the portal and I have picture and sound. I’m using xtream code for login and have no issues on other TVs using firestick and tivimate. This just started happening earlier this last week.
I experience the same problem and for me it's the VPN trying to switch on at the same time the Mytvonline 2 tries to connect to the IPTV server. For best results I disable the VPN, open Mytvonline and connect to the IPTV service then enable the VPN.
If you have a VPN maybe you can try this
Thanks. But my VPN is not connected. I only connect my VPN when experiencing buffering, probably ISP throttling
Yes it sounds most likely to be that. Maybe best to leave the VPN on
