I posted that information because it worked for me and I hoped it might help others. If you can't be bothered to go find that version and try it out!!
Netflix on Formuler GTV
- Apps
- GTV
Oliver76 -
November 28, 2020 at 6:40 PM -
And why you not post it here so that everyone can download it and re-install it on there Formula GTV.
Currently , only the boxes of the Z10 line seem to have no problem with Netflix.
That's right, I've already tested that on the 10 series, the momnet asks you to open Netflix to do an upgrade via Play Sore.
With the GTV version you don't even see it on the Play Store yet
It's available at apkmirror.com
Here in Mata no one buys Formuler GTV any more it don t support NETFLIX. Here Netflix is very popular .
could you send me the correct version for the GTV version. I've installed it but I don't think it's the right version.
Does not work in GTV. I tryed all versions and until know I did not have one version that worked since the error of original app in my Formuler GTV.
all unlinked versions has been removed from the unlinked except tablet version. To use tablet version is quite difficult.
I hope soon or later Formuler can solve this issue.
are there any changes??
Or does anyone have a working version already? -
No nothing hope they find a solution
I’m waiting too
I have switched over to Nvidia Shield, im thinking on to sell my GTV Just because Netflix doesnt run on it.
Indeed. I have netflix subscription but can't benefit. I hope to see any solution soon.
Whats the big thing about Netflix, when you buy the box you know its not got Netflix certification? Yes they has been some links that have worked on Unlinked but no more at the moment,Netflix is shite
get a vod sub with 10 x the amount of content than Netflix job sorted and cheaper
Its not only about lack of Netflix support, its about if you pay 140€ for a streaming box you would expect to see from dev Side some effort to keep their customers happy.
I am disappointed with this box nothing to do with the others, not even talking about the update which takes a year to come out.
If such postings, like from user Multipage (attacks against Formuler) continue, the user will be banned and thread closed!
Good of you Sam well said
Nothing new on this thread?
I hope that someome can find a solution soon.
Still no news.
good day I have a question how can you get netflix on chromecast formular gtv I can't cast it
You have Chromecast in Gtv box
Play netflix with your mobile and then send to gtv with chrome cast.
Or install Netflix on your Gtv box
ajdee is there an solution????
thesedays there isn;t compatible netflix version with GTV.
This Netflix i use works on Gtv box
I have test it
I have install Netflix on my Gtv and it.s works
which version????
Could anyone confirm if the netflix you are talking about works in Formuler GTV since this is a topic to Formuler GTV?
And if it works please share the link.
Best regards
Best regards
Try This one I dont have a netflix account to test with at the moment but this installed and loaded up just fine on my gtv
Can't install this version
I can install that version, but my remote dosen't work in Netflix
I just tested unfortunately there is no control of it once u login. I will keep searching and see if I can come up with anything. As of right now I tried 10 different versions all come up not compatible
Mook -
for the moment only solution the mouse.
Why dont watch netflix via chromecast?
Because we buyed Formuler GTV and not Chrome Cast or other box or pen drive.
And because this is a Forum of Formuler and this topic is for Formuler GTV
GTV has built-in Chromecast lol
