unfortunately,there is not series hot-key option
requested option for BT1 Remote
- Hardware
- GTV
maxiremix -
February 3, 2021 at 8:03 PM -
Hold the VOD key and it will take you to the series.
Where is the VOD key on BT1
You have to assign it.
It should be set as default.
Press the remote control button at the bottom with 2 dots.
Press once for VOD
Press and Hold the same button for Series
Press and hold again and Itl take you back to VOD
You’ll get the idea
This is too complicated for older users . why can you assign a key for it ? . Every body watches VOD and is a must for the senior citizens . The IR remote which came with the Z8 is the best .
I'll swap you 2 old ones for your BT1
EDIT sorry GTV. think its different code to old remotes
If explaining that to senior citizens is complicated, then could always just suggest.
Menu - Vod And / Or Menu - Series for them clients.
Although if just say 2 dot button is vod button then it’s not that complicated really.
Got it , thanks .
Good to know,thank you 🙏
Could the volume buttons on the left be in "TV" mode while the rest of the buttons remains in "STB" mode ?
It's anoying to switch modes to change TV/Home Cinema volume for instance.
Apple TV remote does the trick easily. Tell me if I miss something....
The request is known and was added to the wish list.
If it is possible to implement, you should probably see a new BT1 RCU firmware update pushed out in the Summer to add this functionality.
