Hi guys box being good now started to get black screen. Was on a channel. Changed channel went black and stayed black any ideas guys
GTV BLACK SCREEN
- MYTVOnline2
- GTV
Den123 -
February 7, 2021 at 11:25 AM -
What dose this mean. An error occurred. InvalidresponcecodeException.
We are already checking this error, seems something with channel decoding goes wrong.
Until now this happen only to you and Mevi once, if this happen again please note the channel + category and send the Info to me in PM. Thx.
Thanks Sam will do
one of my lot been getting this black screen then changing channel on its own
Must be alien GTV when the GTV change alone channels.
Sorry but i could not resist Mr. Tran
Happens on the Z8 also. Good luck--------
I´m having a problem with black screen, but it´s minute by minute when i´m watching the same channel. Any ideia of what can i do?
I also have the same issue and I have done since I firstly got the GTV. I get a black screen with this error. It happens on different channels. The channel seems to work, go black and show up with the error “InvalidresponcecodeException” and then works a few hours later.
Doesn’t happen on any of the Z8’s I have, only the GTV.
The channels that are down get a black screen very late if you compare to Z8, first frozen image a couple of seconds than black screen.
I have the same error, it only occurs with channels that are FHD. SD and HD work fine. Tried different providers and it always happens if I choose a FHD channel. The channels are up, if I use a different app it works. The provider said perhaps change the streaming style from hls to ts but MOL2 doesn’t have a option for that.
