New beta software for Z8 Pro, Z8, Z Alpha, Z+ Neo, CC released.
Firmware Version : 1.5.0 BETA
MYTVOnline 2 : v.7.12.0 BETA
WARNING:
HowTo Install:
Home Menu -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press "OK" button for install.
Beta SW 7.11.2 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Change Log
- NEW: Add MYTVOnline2 channels to the home screen
- Access from: Launcher Settings > Customize Channels
- NEW: Google Assistant integration for MYTVOnline2 Live TV channel search
- NEW: Add USB Tuner Support for Hauppauge WinTV-dualHD DVB-T
- NEW: Add USB Tuner Support for Hauppauge WinTV-dualHD ATSC
- NEW: Add USB Tuner Support for Hauppauge WinTV-HVR-955Q ATSC (2040:b150)
- IMP: Improved screenshot path selection menu
- NEW: Toggle 'Auto-connect to last portal' ON/OFF
- Access from Settings Menu
- NEW: Add option to Disable Adult content lock
- Access from Settings > Parental Options
- FIX: App crashes after playing certain contents
- FIX: Subtitles not displayed with certain subtitle codecs
- FIX: Multi-Adult category locking issue
- FIX: Recording fails if event stream is not started yet
- IMP: Auto-scroll long category names
- IMP: Add new translations: Polski, Norsk Bokmål
Great GTV function on MOL2 Z Boxes ![]()
