Is it worth the upgrade? Currently using 3 z8’s…Any other upgrade recommendations?
Z8 vs Z8 Pro?
- Z8
Bluewater -
September 6, 2021 at 3:05 PM -
I would rather go for the Z10.
Agree with Mevi. From z8 to z8pro is the upgrade tiny but Z10 is something different (higher OS, Av1, SD Card, 4GB Ram, better CPU and GPU).
GTV is also worth considering
Higher OS, Sam?
Higher OS, Sam?
Yes...
Z8 have Android 7 and Z10 Android 10.
Like 175 mentioned GTV is also very good alternative for upgrade.
Thank you
Z8’s seem to perform well with our IPTV service, I will look at these recs to see if a change is worth it.
Are these worth a look for this basic streaming usage? Or can they provide better results?
Z8 pro is already full optimized for IPTV, of course there is always place for new features. For basic and advanced streaming one of the best boxes, next would be only GTV and Z10.
Z10 MAX is compared to Z8 the new generation and have new OS Android 10, micro sd card slot, integrated antenna, 4GB RAM and faster CPU and GPU.
If you are happy with z8 pro and need more boxes, buy again Z8pro because this box have enough power for next years.
At end it is always the users point of view that decide to stay with current line or upgrade, depends all from users need.
