I am looking for the information in https://support.formuler.tv/kb/article/120…p-soundbar-avr/ but for the Formuler 11 Pro.
How to Set up a Soundbar
- Z11 Pro
- Help
dwayne -
March 23, 2023 at 1:04 PM
same process applies
however, kindly note using the spdif option maybe easier to get working compared to hdmi arc because of hdmi compatibility in certain cases.
hi
little reaction; afaik there's no spdif on Z10&Z11 (which I find a pity personally)
The options described in https://support.formuler.tv/kb/article/120…p-soundbar-avr/ don't exist on the Formuler Z11 Pro, otherwise, I would not be asking my question.
Home > Settings > Device Preferences > Sound > Digital Audio Format > Auto or Manual does not exist.
There is Home > Settings > Device Preferences > Display & Sound, but no "Auto or Manual" choice beneath that.
for z11 it is at:
settings>device preferences>display and sound>advance sound settings
or developer options>audio>hdmi output
the audio is under vender above others
Easiest way I’ve found is this:
TV and Soundbar connected together via optical (spdif)
Formuler connected to tv via hdmi
I paired the volume control from soundbar remote to GTV IR1 learning remote (white buttons) and use these controls to deal with the sound from soundbar directly.
For general volume I simply use the standard remote buttons
PostRE: Soft sound / no Dolby 5.1
Does your Sonos have HDMI ARC?
It sounds like you don't have your equipment connected in the optimal way.
Optimal:
Connect all your devices to the TV using HDMI.
Connect your Sonos and TV using the HDMI/ARC port on the back of the TV:
175nMarch 13, 2023 at 9:31 AM -
that's why i suggested earlier to use spdif because it is the easiest way to connect sound bar to tv without issues.
even if the tv has arc some times it will not play nice in the way that you want without some extra configuring.
also most iptv providers don't have the extra audio features in the content that can be experience from the hdmi.
