Is there a way to access system files on my new Z11 Pro Max? Last week I upgraded from a Z7 and there never was a issue having full access to Android > Data using an older version of ES File Explorer. On the Z11 it shows the Data directory as empty. I've tried a number of file explorer/managers, such as, a newer ES File Explorer, Solid Explorer, MiXplorer, CX File Explorer, and a few others, all with the same result....directory empty (yes, I know to check Show Hidden Files). I have gone over all my permissions a few times now and I think they are good. Any suggestions? Thanks.
Z11 System Files
- Z11 Pro MAX
- Help
SayUncle -
May 22, 2023 at 3:58 PM
Same issue as any other box or stick running Android >10. Chromecast 4k, xiaomi mi box 2nd, xiaomi mi stick 4k, etc only nvidia shield corrected it in a certificated box i guess...
The problem of doing this is that you will also get a way to gain access to other system folders that you shouldn't...
But yes, it's a big let down, at least they should have enabled android folder completely by default...
z11pronotmax , I see, thanks for the reply. I knew it was something that I couldn't get to the bottom of to correct, as I usually persist, and with the help of the forums figure things out eventually.
I wonder if this is something that can be over come with a correctly coded File Explorer, or is this something that just has to be lived with going forward with Android >10.
if running windows you can use
[TOOL] Android File System (Network ADB Extension) for Windows Explorer
from the XDA Forum
but external storage must be fat32
Have you tried using TV file commander….
App is available in Market app
Connect from computer to Formuler box wirelessly
Many menus and sub menus accessible using this method.
Hi adrilang , thanks for the suggestion. I did try Total Commander as well, but not File Commander. Do you have the version number that seems to work for you and I'll download an APK for the exact same version, so it will be apples to apples. Thanks.
