i have bought a z11 promax and have decided to install tivimate,if tivimate is used on nvidia shield it can only record 4gb because of fat32 has to be used.
With tivimate on formuler z11 its possible to record to internal memory unlike with mytvonline3,does this mean that i will be able to record files without 4gb limit,as the formatting is likely ntfs?
