No, there is not many times it have happend
Automatically Booted out of mytvonline 3
- Z11 Pro MAX
- MYTVOnline3
RoccoHD -
September 26, 2023 at 5:35 AM
Still happening daily constantly and it’s frustrating, hopefully fixed with next update . Those that posted they were experiencing this previously are you still experiencing it??
Only once since last update
hi
Here I get kicked out of MOL3 to the home menu (happening since the last update a few months ago):
- After starting up MOL3 directly after startup of the Z11 PM. If I wait about 30 seconds and then start MOL3, all is ok
- In the content manager menu: when I push my programmed botton 'live tv' -> home menu (bug) ; from all other menus the programmed botton 'live tv' works fine.
Hope this can be solved.
Did you not installed last update? Even if small change done, but since then i didn`t see any kick out to home menu anymore. Try and test.
This also happens to me, but only when I put the box in standby and switch it on the next day, the contents are then refreshed and after 30 to 60 seconds or restarted, this phenomenon occurs regularly and only so far on the Z11 pro max
hi SAM: yes, always latest updated directly (edit: I believe this started a few updates ago)
hi Ben C.: same here (but contents are refreshed most days, but not always)
Mine refreshed every day
Please install latest Beta, fix is included.
Happens to me as soon as a Recording kicks in. Updated to the latest version today. Still happening
Log tracking: 0000001937725
SAM i got 2 boxes on 1 of them every day around the same time the mol3 launcher closes automatically and brings me to the home screen. Both on latest software
Track ID: :00000019D7DE1 -
Track ID: :00000019D7DE1Try install latest beta.
Go to software update. Type on your remote 1339.
Push red button on remote and install. Maby it helps.
Check your USB recording device on pc for errors and bad sectors or try to use same brand usb stick if no name product in use. Format on PC with NTFS and try again.
Still happening latest software
Close on the box with issue all apps and if USB device connected, disconnect and restart box once. if same happens, reinstall MOL3.
Fix for this has been included in the latest beta.
Please try to install the latest beta, and let me know the results.
To access the latest Beta update for your Formuler devices :
Access Code: 1339
1. Open the Software Update app
2. Enter the appropriate access code, then press the red box button
3. Start Download -
Mytvonline3 keeps kicking back to home page during series. Tried closing the app and device but still same issue.
Tracking ID: 00000019DC716 -
Tracking ID: 00000019DC716Try te remove mytvonline3.
Restart box. Not standby but restart!
Install it again from market.
Check also if you have latest software update.
