how to edit portal
  • Hi there looking on how to edit my portal on friends Formuler Z11 Pro Max box. My server updated their portal what steps do I need to do thanks.
    In mytvonline go push menu, connections
    Choose connection you want to edit
    Push ok, disconnect, push ok again and push edit.
    After editing push update, otherwise it wont update you new credentials.
    Then connect again.
  • I just swiched server of the same provider,and i did edit as you wrote,but each time i got :unknown Portal,code 1005-400.
    In the end i decided to delete the Portal and addPortal with new credentials,in the end it became clear that i made a mistake,took z for 2,so mistakes easily happen when editing a Portal,so i would advice to add from scratch and check at least 3 times before connecting:grinning_face_with_smiling_eyes:
    Wel done.
    Sometimes you can get error. Mostly big letters or i or l😂
