Hi!
I recently upgraded my fiber from 250/250 to 500/500 and still having the same results while doing speed test. The exact same amount, like 94 mbits.
I have tried wifi aswell and getting some mbits more on one test and less the other time i test so its not stable enough to go with.
Setting the box up with a lan cable straight from the router and not from the port in the Wall that the guys who installed it sat up doesnt make any difference, maybe 10-20 mbits TOPS.
What can I do to fix this?
Bonus question: While testing around I was about to screw the wifi antenna more firmly and it made a noice then went around to get loose again. Did I break it? Wifi still works but were very bad after this. Havent tried it out anymore since so now idea how it works out right now.
