Hi, sorry if this has been mentioned before but I can’t find a solution anywhere.
I’m using a Zmini with the mytvonline3 app and some movies in VOD are shuttering/stalling, I tried changing different settings but nothing worked. It’s also the same in my Z11 PRO MAX.
When i change to the vlc external player the movie plays fine with no issues.
The video information from the vlc player is
Codec MPEG-H Part2/HEVC (H.265)
Resolution 1920x1080
Framerate 23.976
Video information using default player
1920*1080 23.976fps H.265/English, AAc,5.1Bitrate: 28.6Mbps
Also I’m using XC with username and password
I downloaded other apps and the movie plays fine.
does anyone know a solution to get the movie to play with mytvonline3 built in player or is it not compatible with the codes above?
